civic starts and dies a second later.
Old Jul 24, 2011 | 12:24 PM
umair's Avatar
Default civic starts and dies a second later.
i just installed a b16 into my civic and it started right up. i started it about 5 times but never got a chance to drive it. today i was going to drive it but it started for a second and died. i checked all grounds and they were fine. had a spare relay and still no go. i hear it click too. when i spary starting fluid it stays running. i hear the pump priming also. i cant try a different computer because the car is on e 85.
this is the only thing i could find and i dont know where it goes. it runes with the fuel line to the fuel filter. however i dont know if this would cause my problem.
Old Jul 24, 2011 | 02:46 PM
Sean @ ESG's Avatar
Default Re: civic starts and dies a second later.
Have you checked the timing? Is the car getting spark? It kind of sounds like it's not getting fuel.
When I have my fuel pump cutoff on, the car will start with whatever is in the system, and then shut off. After that it will just crank and crank but not start.
Old Jul 26, 2011 | 11:19 AM
umair's Avatar
Turned out to be a bad connector at the tps.
Old Jul 27, 2011 | 10:50 AM
nunezzzzzzz's Avatar
TPS?
Old Aug 1, 2011 | 06:46 PM
xreaverx's Avatar
Originally Posted by nunezzzzzzz
TPS?
Throttle Position Sensor
Old Aug 2, 2011 | 10:19 AM
i have the same problem replaced the throttle position sensor my car dies if i gas it too hard =P bvut if i gas slowly it works like super slow
Old Aug 2, 2011 | 11:06 AM
grumblemarc's Avatar
The Grumpiest
You replaced it. But did you calibrate it? You didn't say.
weaponsgrade
Jan 8, 2010 09:55 AM
JsSIR
Apr 28, 2009 05:25 AM
white94
May 17, 2007 08:22 AM
SoCal ITR
May 6, 2004 10:27 PM
