HELP! b18b1 flywheel wont mate with 90-91 LS/b16 exedy clutch!!
Old Oct 2, 2002 | 02:23 PM
giooooo's Avatar
Default HELP! b18b1 flywheel wont mate with 90-91 LS/b16 exedy clutch!!
liek the topic says, im bought an exedy clutch 90-91 integra trans and the clutch wont mate up with the b18b1 flywheel. the dowel holes are in different positions. Is the b18b1 and b18a1 flywheel different? will a 92 93 b18a1 flywheel work anyone had this problem in their crx/integra swaps or its jsut i happend to have a b18b block with a 90 91 ls tranny that wont fit.
[Modified by Giovannie, 11:25 PM 10/2/2002]
Old Oct 3, 2002 | 12:43 PM
ivanED9's Avatar
Default Re: HELP! b18b1 flywheel wont mate with 90-91 LS/b16 exedy clutch!! (Giovannie)
u need the clutch kit for the cable operated cars, b18b is hydraulic, b18a is cable
Old Oct 3, 2002 | 01:27 PM
Jeff C's Avatar
the dowel pins do go a certain way. have you rotated it?
when i put my exedy clutch on my CM flywheel, it did take a little persuasion (rubber mallet). one dowel pin was off slightly.
hydraulic and cable should have nothing to do with it.
Old Oct 3, 2002 | 02:22 PM
giooooo's Avatar
Default Re: HELP! b18b1 flywheel wont mate with 90-91 LS/b16 exedy clutch!! (Jeff C)
yeah i tried rotating it 120 degress and rotating rotating till it fit and it worked
Old Oct 3, 2002 | 02:36 PM
blundar's Avatar
if you get stuck hard I have 2 B18A flywheels I'm not using. Email me if you need one. zip 45219
lvlrkmart
Jun 29, 2009 10:14 AM
Jonny Rocket
May 18, 2009 09:03 AM
impreziv
Jul 20, 2008 10:53 AM
Origin
Sep 11, 2005 08:00 PM
DA-B16
Mar 28, 2004 11:55 PM
