flywheel compatibility
Old Mar 28, 2004 | 12:46 PM
DA-B16's Avatar
Default flywheel compatibility
I have a b16a1 In my 91 Integra with a demolished flywheel. Will a replacement for a del sol from autozone work ? or will I need to find a more specific application. If so , where do I find one? Any help would be greatly appreciated.
Old Mar 28, 2004 | 12:56 PM
civickiller's Avatar
Default Re: flywheel compatibility (DA-B16)
from what i understand, you have to use the same clutch with flywheel. like if your using a 90-91 teg clutch then you gotta use a 90-91 teg flywheel. so if my understanding is correct, you gotta use a del sol clutch too. but idk if a delsol hydro clutch will work in a cable trans
Old Mar 28, 2004 | 02:22 PM
DA-B16's Avatar
Default Re: flywheel compatibility (civickiller)
I got a clutch from a shop here in san diego. But I failed ask about a flywheel thinking it did not need replacement. They are closed today so I will probably call tomorow but I am not even sure what clutch they gave me. I just told them I had a B-16 with a cable tranny and they gave me an ACT stage 2. Hope It works.
Old Mar 28, 2004 | 03:30 PM
if they know what they are doin they would have gave you a 90-91 integra clutch because thats the clutch you would use on a b16a1 with cable tranny, so you would get a 90-91 teg flywheel
Old Mar 28, 2004 | 06:49 PM
Boges's Avatar
Any b-series flywheel will work.
Old Mar 28, 2004 | 11:55 PM
DA-B16's Avatar
Thanks guys. I am going to call the shop tommorow and ask them what clutch they gave me
Jonny Rocket
May 18, 2009 09:03 AM
impreziv
Jul 20, 2008 10:53 AM
Origin
Sep 11, 2005 08:00 PM
BloodPressure
Jan 21, 2005 03:36 PM
89a6T
May 9, 2004 04:27 PM
