jdm d15b Vs. d16z6 difference?
Hey im just curious the differences if the jdm D15b and d16z6 cause i wanna start a turbo build and wanna know which one is best for that application
z6 more "aftermarket" support such as rods and such. everything is pretty much identical except rod length and crank, deck height. the 1.5 has a better Rod 2 stroke ratio meaning you can rev higher and less wear on your cylinder sleeves. but the 1.6 has a bigger crank meaning you will have bigger displacement and more torque. and also easier to find rods and such.
alright thanks alot. when i start the build i would like to build the bottom end and such. i havent seen a lot of atermarket parts for the jdm d15b. much more for d16. ima take a look at the zc motor.
Slammd Sol
37
Jan 11, 2005 03:52 PM
