Could I use this wiring harness?
Old Jul 23, 2011 | 08:28 AM
Sweetfish89's Avatar
Default Could I use this wiring harness?
I found a 97 civic wiring harness for $40. I was wondering if I could use this for my mini me swap into my 90 civic hatch?
Old Jul 23, 2011 | 01:03 PM
civickiller's Avatar
Default Re: Could I use this wiring harness?
what year is the head/im from?
is your car obd1?
dpfi or mpfi?
Old Jul 23, 2011 | 01:08 PM
I'm not sure what year the head is from by it is a z6 head and IM. Getting ready to do my obd1 conversion and mpfi.
Old Jul 23, 2011 | 01:21 PM
only thing i would use off that harness is the o2 plug unless your getting obd2 dist and injectors to use.
with the z6 being obd1, a obd2 wire harness wont help much unless getting the parts i said above. only injectors, dist, o2 plug wont work on the new obd1 manifold.
when doing the dpfi-mpfi on my old car, i used the stock dist plug, both sides, to create a plug for the wires going to the ecu so you could take out the motor with the engine harness
Old Jul 23, 2011 | 01:24 PM
oh and you can tell what year it is by looking above the header will have a 9|3 stamped for a '93 or whatever year it is
Old Jul 23, 2011 | 01:26 PM
Ok thank. So probably would just be easier to just get a 88-91 SI or EX harness?
Old Jul 23, 2011 | 02:37 PM
again just for parts. if i remember correctly you cant just swap in a si engine harness into a dx
but then again the z6 injectors are obd1 and dist is either obd1 or 2 depending which dist your gonna run. but its easier just to mod the stock harness
theres a whole bunch of combos u can run. so harness you can steal plugs from depends what components are used.
obd0 injec, obd1,or obd2, same as obd1 just different plugs dist
obd1 inject, obd 1,2 dist
obd2 inject, obd 1,2 dist
Old Jul 23, 2011 | 03:20 PM
I'm not sure what dizzy I am going to use either z6 or a6 just need to find one. So I should get obd-1 plugs for the dizzy and injectors and solder them onto my harness.
Old Jul 23, 2011 | 04:51 PM
u need a obd1 or 2 dist for obd1 conversion
if u already have the obd1 injectors, then yes i would just get the obd1 injector plugs
accord2civic2prelude
Aug 14, 2009 05:42 AM
integra_661
May 13, 2009 10:48 PM
TGrant
Apr 19, 2006 02:25 PM
JDM-97CX
Aug 15, 2005 08:54 AM
Cesare
Jun 5, 2005 03:54 PM
