d16 y7 starting issues
I need some advice ht.... I have a daily that's a 97 civic hatch automatic.. car just keeps cranking and will not turn on... I check for spark and theres spark. I check the fuel system and I can hear the pump kick on and I cleaned the injectors now when I pulled the injectors still attatched to the fuel rail I told my friend to turn it on and quickly shut it off.. I held the injectors about a quarter of an inch above the mounting holes.. car started right up... It seems the car is getting to much fuel? So I put everything back together then it turn on for two trys after that just kept cranking anyone ever had this issue? Any help will be greatly appreciated
What do you mean compression is good? What numbers did you get when you did the tests? Did you check both mechanical and ignition timing? Not doubting you but "is good" doesn't indicate much of anything.
ORguy
10
Mar 22, 2011 05:25 PM
