Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: How to Adjust Valves
Step by step instructions for do-it-yourself repairs.
Valve Lash adjustment help!
on the sticker under the hood it says valve lash IN 0.26 ± 0.02mm EX 0.30 ± 0.02mm
on my feeler gauge set from what i think is 0.02 it says .002 and under it .051 and under that is mm and its really thin one of the last gauges in the set almos tthinest ... and the other is twoards the thicker at the end says .020 and under it .508 and under that mm so im confused as hell ....which feeler gauge is the sticker asking for on my f22b2 non vtec and do i have the right one in my set?
also what is even more confusing in the book(chiltons) it says on one page:
valve lash adjustment specifications:
intake: 0.26mm (0.010 in.)±0.02mm (0.0008in.)
exhaust: 0.30mm (0.012in.)±0.02mm (0.0008in.)
and on the next page engine tune up specifications:
In:0.009-0.011
Ex:0.011-0.013
idk why it has different specifications or which is the correct/better ones ... but im confused on how to read it or look for the right ones on my feeler gauge set...
In:0.009-0.011
Ex:0.011-0.013
Yes in the FAQ there is a write up.
Metric and inches.....
If you have a .010 and a .012 (inch), you are good to go. If not you may have to take two "feelers" on your set together to get the proper thickness (a .007 and a .003).
Good luck
Good luck
the book doesnt even say those specs where r u getting this from? i want the correct ones ...
and i still dont get how to read the specs .... also i looked in the FAQ and couldnt find what im looking for...
Honestly, I usually shoot for the tighter end of the clearances.
0.009" Int and 0.011" Exh. (F#@k'n imperial units :shakeshead: ) If there are any issues upon start up, I will back it off the 0.001". However, I haven't had any issues up to this stage in the game. :knocks on wood:
ima get the freon for my ac at begining of month when i get some spend money ..
Good deal on the ac....know what you mean by funds, had to borrow from the Chevelle fund/savings this week, which means I'm going to have to put off the "next" motor until next year
just to make sure when your on a specific cylinder all but that specific cyl's valves should be closed right? example when im on cyl 4 , cyl 3 intake valves have play and cyl 2 exhaust also ... shouldntthey be closed have no play?!?! i used .009intake and .011 exhaust since they were set like that from when i went to honda and they did it ... only a few valves were off a bit so i made them the same ... also when im on cyl 2 , cyl 1 ex valves play and cyl 4 in valves play .... is it supposed to be like that?? im not sure .... they are all tightend to the exact feel of what they should be so ...?!?!
and when im on cyl 1 , cyl 3 ex play and cyl 2 in .... so basicly what ever cyl im on those 4 valves play but then 2 from 2 diff valves also play ... is that how it should be?
ok so i checked them all last time i got it done was by honda ... but they charge too much so ... they did .009 intake and .011 exhaust so i just went by that cuz i wasnt gonna loosen them .... and only a few were off a bit .. just got it so the feeler gauge drags a bit and the same as the other valve in that specific cyl so i matched them up ... so i put everything back and i dont notice a difference still ticks and knocks ... so i wasnt gonna tighten them any harder .... now im below mininum oil so ... idk if that would make much a difference but, also my friend told me it might be the oil pump not oiling them up right ... idk ik last time i got a valve adjustment at honda it sounded perfect ... but if they are already at exact tightening idk ....?!?!!?!
yea i put in half a quart thicker oil 10w-30 now its perfect on the dipstick and my dad listened to it and he said it deffinatly sounds way better said its supposed to sound like that so ... i guess i did good , other than that just needs new springs n other worn out stuff but its good so im glad i guess .
so thnx for the info specs and help guys!
Ok, good to hear.....save up, plan it out and you'll be fine....heck at this oint you might as well put the ac off until next spring.....where you live you've got what a month, month and a half?
yea only a month tops of some hot weather ... and thats not every day .... so ac isnt important here ...
In:0.009-0.011
Ex:0.011-0.013
In:0.009-0.011
Ex:0.011-0.013
spidermancivic
Dec 2, 2005 11:21 PM
