compression excellent, but smoke
Old Jul 21, 2011 | 09:31 AM
davidjames1983's Avatar
Default compression excellent, but smoke
my civic em1 86000 on the clock . is eating oil like a monster. did a compression test at honda dealer came back 1. 205psi 2.200psi 3.200psi 4.206psi. so as far as i know all is good. but that leaves the problem of where the oil is going?????????? plus there is no oil leaks. any ideas????
Old Jul 21, 2011 | 09:34 AM
Drive 4 fun's Avatar
Default Re: compression excellent, but smoke
Smoke! Color? Where your oil is going. Compression does not mean no oil burn.
Old Jul 21, 2011 | 09:36 AM
Search, here is similar and there are many threads.
https://honda-tech.com/forums/showth...il+compression
i would say blue so where u reackon it comin from. i thought if u had good compression then ur pistons rings would be fine??? or is that not the case?
Old Jul 21, 2011 | 09:38 AM
Oil rings, valve seals and guides. The thread and your response were at the same time, so you will get most of the answer there.
Old Jul 21, 2011 | 09:45 AM
oil rings ?? where are they located
Old Jul 21, 2011 | 10:00 AM
http://courses.washington.edu/engr10...on%20Rings.htm
Old Jul 21, 2011 | 10:04 AM
didnt know they all had seperate names, just thought they were all call pistons ring. lol cheers
Old Jul 21, 2011 | 10:21 AM
So now you can searh HT using words: blue smoke compression oil, in various combinatins and get lots of info.
DarkDragon
Oct 28, 2005 04:15 PM
Layziebtnh055
Jun 22, 2004 03:25 PM
cgap
Jun 18, 2004 01:15 AM
Witty
Jul 3, 2003 06:20 PM
