a/c repair is more frustrating than women
In fact women are almost MORE predictable.
Low side 50-55psi high side 270-275psi at around 95f
suction tube is cold
discharge tube is warm
pressures equalize very slowly with compressor(new) off
condenser fan works
blend door is working properly
no leaks (uv tested, even the evap)
vacuumed to -29inhg for 45 min
charged BY WEIGHT as per honda's manual with a digital scale
its still. not. f#*&ing. cold.
tepid if anything.
Give me a reason why I shouldn't push this car off a cliff.
1997 Civic CX
condenser fan works
tepid if anything.
1997 Civic CX
Glad to hear I'm not alone
The only thing I HAVEN'T replaced in the last year is some of the hoses. Evap, exp. valve, condesnor, compressor, drier ALL new.
had the same issue in my cummins, turned out to be dust on the front side of the a/c coil and is was basically all muddy (lived on a dirt road so dust got on/around the coil)
back washed the coil via the drain hose and viola cold a/c!!
Your high side pressure looks too low and the low side looks too high for 95F. But the service manual states that pressures should be taken with the engine idling at 1500 rpm, so it's not possible to evaluate your pressures. Redo the measurements with the engine idling at 1500 rpm.
Skip step one and instead hook up your manifold gauge set.
Btw the new compressor had an oil charge in in it from the factory.
As for the pressures I will re test them and be back with results late tonight or tomorrow
A few things there is thermo switch ( i think it called on the compressor) a 70 dollar part should be changed when you change the compressor. Also check the switch on the dryer with an ohm meter.
on my quest for colder AC I removed and cleaned the evaporator with some simple green and a pressure washer. remember to get new O rings for the lines at the firewall if you do this.
I noticed an immediate difference.
I have executed the test. I have tried for life of me to decipher that chart but I'm at a loss. I beg assistance.
Here are my readings:
Temp outside: 89f
Temp at intake: 86f
Temp at vent: 68f
Low side pres: 30psi
High side pres: 225psi
Humidity: 76%
Temp outside: 89f
Temp at intake: 86f
Temp at vent: 68f
Humidity: 76%
What should those numbers be? Yes it was 1500 rpm.
I replaced the control panel. Fan switch blend lever/buttons and all! It got shorted out by a bad wiring harness which I also replaced
Hello all...
I wanted to ask a question about the high side pressure readings. My needle has a constant jittering when the compressor is running. Its only hovering from about 200-225 psi at idle.
Sorry if this a noob question...first time here and trying to learn how to decipher those charts too!!
Thanks again for everyones help in advance.
Thanks for the help with the charts! I was able to do some more leak checking and found the expansion valve is leaking. Going to replace it soon i'll let you know how it goes!
during vacuum, pause and hold. watch the gauge for a few minutes. walk away for half an hour. it must hold 29 inches of vacuum. if not, you have a leak.
iv
14
Aug 11, 2014 10:56 PM
