turbine shaft .. extra groove ? .. missing seal ?
This is my turbine shaft in question (Garrett T3, Stage 3). Took this out and noted an empty groove near the oil seal, is there supposed to be a seal there or is this groove seal-less ?
Also, I developed an oil leak from the turbine side .. does my turbine oil seal need replacing ?
I want to say when i had mine apart it look like that had an extra groove but I'm not sure hopefully the shodan pops in here.
no there is not a seal that goes there just the piston ring style seal.
For it needing a seal i say yes cause you can see where it has been burning oil and getting by the seal
Normal to have the groove. Piston sealing ring could use a replacement, and the journal bearing goes infront of that groove on the shaft itself. Make sure it is properly lubed before you install the journal bearing before start up
how much shaft play is too much shaft play? and is there such thing as a natural amount of shaftplay
b18sihatch
Apr 12, 2006 08:17 AM
BauleyCivic
30
Jul 4, 2004 09:41 PM
