Suspension & Brakes Theory, alignment, spring rates....
Steering wheel not straight under hard braking
Old Jul 18, 2011 | 08:12 PM
blaak-crx's Avatar
Default Steering wheel not straight under hard braking
So, I just did an alignment on my Crx because I changed the steering rack. Now on the race track; under hard braking, the steering wheel is not straight. It feels like it needs to turn to the right to brake straight. It was fine before the alignment. New: left = 2.89/right = 3.11 degree front camber and left: -0.04 & right: -0.05" toe (toe out). The guys didn't want to spend more time to make both sides equal. As for the camber, I have a camber kit but they are set to max adjustements. Can the mini difference be the cause. Under light braking, it seems to brake straight. Bad alignment?
Old Jul 18, 2011 | 08:27 PM
Drive 4 fun's Avatar
Default Re: Steering wheel not straight under hard braking
What was the toe before? Also toe out? I did not like toe out, in front, on the track.
Old Jul 18, 2011 | 09:31 PM
blaak-crx's Avatar
Before: -0.03" toe out.... left: -1.0, right: -1.3 degree. Edited first post...
Old Jul 18, 2011 | 10:10 PM
abs0Lut's Avatar
What kind of backyard mechanics are doing your alignments, WTF.
Old Jul 19, 2011 | 03:10 AM
blaak-crx's Avatar
Ya, the first time and last time going there. It was a garage near my home and charges regular price for a modified car. I usually go to another but he charges way more for modded cars. 68$ vs 100$
Old Jul 19, 2011 | 10:26 AM
Could the different camber give different contact patches, exaggerated under load of braking and pull to most contact side? Again, I found toe out in front, and rear for that matter, not much fun at track speed and hard braking. I use 0 toe front and rear as minimal toe in as he can set, reproducible to each side.
Old Jul 19, 2011 | 06:49 PM
blaak-crx's Avatar
0.22 degree of difference. My last set-up had similar differences and it was fine. I've had -0.06" (-1/16) toe out before and it drive good. Better turn in. Anyways, I'm not here to discuss about which toe is better... I'll be going back on the alignment machine and check out my caliper too.
Old Jul 19, 2011 | 08:31 PM
Sorry, I was not trying to discuss toe preferences, except that toe out accentuated tendency to want to turn under braking. It could be magnifying a difference in contact patch from camber difference. Also, have you checked rotor temperatures. One side grabbing harder and heating more. Since toe is equal, and you had it that way before, it probably is not the primary problem, but may magnify other differences. I am aware that it helps turn in, the reason I tried it.
Old Jul 20, 2011 | 08:29 AM
blaak-crx's Avatar
Good idea about rotor temperature! Will try it with my pyrometer! Thanks!
BRN12345
30
May 12, 2008 10:56 PM
dafuzzbudd
22
Feb 20, 2007 11:17 AM
5spdIntegra
Jun 8, 2005 07:38 PM
ultimatehonda
Jul 8, 2003 03:28 AM
vteg
May 22, 2002 06:17 PM
