info on my turbo compressor map included
Hi everyone i got a turbo for free from work and was wondering how much power it could make and what its worth. It is a garrett with a t4 flange that says .70ar on the hot side.
any help is appricated
thanks in advance
eddie
thanks in advance
eddie
sorry it took a while but this is what i got
Comp. Inducer-91mm housing says A/R.83 M24
exducer-71mm has 7 large blades with 7 small blades between them
turbine. couldn't get the measurements cause mu calipers weren't large enough but roughly 82mm 11 blades housing says, its in a line like this heading down from the turbine inlet flange.
A/R
1.05
M1
G2
A/R
1.05
M1
G2
this link looks just like mine but no one identified it there either
http://www.rx7club.com/showthread.php?t=945559
I am not sure what it is exactly, but from the graphs just comparing them to the one you have its in the range between a gt35 and gt37. If you do some searches and find out exactly what to measure on the wheels you can find out a lot more. I think its has something to do with the ratio between the lager diameter and smaller diameter of both compressor and turbine wheels. The numbers you were talking about on the housings from what I understood has to do with the size on the housings and not the wheels themselves.
InTraining124
Jan 30, 2009 01:05 PM
boosted_zc
Dec 10, 2003 08:31 PM
390s, 91mm, acura, compression, compressor, garrett, image, m24, map, maps, mytubo, myturbogeorgian, pd, rdx, turbo
