Help!! ls vtec
Old Jul 17, 2011 | 08:23 PM
thanhzz's Avatar
Icon3 Help!! ls vtec
Hi, I just recently installed a skunk2 manifold and also upgraded my fueil injectors (310cc) and an aem fuel rail. I know I need a tune, but when I first fired her up and took it for a spin, vtec kicked in fine and car redlined fine. After a few days I decided to engage vtec but as soon as it hits 6k rpm the car completely bogs. Any ideas? I've searched alot and found alot of questions similar to mine but have not found any real answers. Also I have an LS tranny, I usually am about 3k rpm at 80mph and this time I'm at 3.5k at 75mphThanks
Old Jul 17, 2011 | 10:01 PM
mouab18c1's Avatar
Default Re: Help!! ls vtec
Old Jul 18, 2011 | 10:58 PM
thanhzz's Avatar
so wouldn't it effect my tune since the installation, it worked fine for that day but after a few days and I tried it again, it started bogging
Old Jul 18, 2011 | 11:29 PM
mouab18c1's Avatar
You got alot of reading to do. When adding new injectors you need to re calibrate it in your tune. 240cc and 310cc are two different numbers. If you can't afford it then but your stock injectors or whatever you had before back in.
Old Jul 19, 2011 | 10:57 AM
thanhzz's Avatar
thanks, just wondering why it worked and a few days down the line it started to bog thats all. but thanks for your input.
Old Jul 19, 2011 | 11:12 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Why did you put in 310s? Do you NEED them? Is this some high compression motor?
If not, you wasted your money, take them out, put stock injectors back in, problem solved.
Old Jul 20, 2011 | 01:43 PM
thanhzz's Avatar
well my ecu on crome was reflashed with the 310cc on them. I got the 310cc with my other things i bought so i installed it cause im planning to get it built soon
Old Jul 20, 2011 | 01:58 PM
Mattb16teg's Avatar
Community Builder
Injectors are something you do last, you are wasting money and causing unwanted problems jumping the gun by installing them now.
Old Jul 20, 2011 | 08:19 PM
lpparker97ls's Avatar
The difference is your ecu has adjusted to the different A/F ration and is running rich because it thinks you have smaller injectors.
Old Jul 21, 2011 | 12:26 AM
thanhzz's Avatar
i tried swapping back to stock injectors and it's still the same...........
Old Jul 21, 2011 | 01:48 AM
mouab18c1's Avatar
So what injector size do you actually have on your ecu? Stock or the 310's?
Old Jul 21, 2011 | 02:15 AM
thanhzz's Avatar
i have two ecu, one for 310cc right now and the other one stock 240cc. i tried both the one that is set up for 310cc runs like crap and the 240cc better but still happens like before
Old Jul 21, 2011 | 02:18 AM
thanhzz's Avatar
i think i might find an answer http://www.carolinahondas.com/tech-t...er-solved.html gonna see if i can borrow a obd1 vtec dizzy and see
Old Aug 28, 2011 | 10:10 PM
thanhzz's Avatar
I figured out the problem guys!! My dipstick was dead on the full mark but due to frustration i added a lil more oil.. maybe 1/4 of a quart and vtec works fine but then my oil is kinda past the dipstick... what should i do?
Mrmopar
Dec 24, 2012 06:54 PM
