code 22 wont go away no matter what
Old Jul 17, 2011 | 07:59 PM
Travis R's Avatar
Default code 22 wont go away no matter what
vtec was working fine and the CEL came on one day for no reason and its code 22.
i redid all of the wiring to make sure everything was connected right. didnt work
ive tried to bypass by connecting a4 to d6. no luck
i tried grounding d6. didnt work
tried resetting the ecu many times. as soon as i put the key in it pops on and stays on.
could somthing be wrong with the ecu? why wouldnt the bypass work for me.
Old Jul 17, 2011 | 08:12 PM
Former User's Avatar
Default Re: code 22 wont go away no matter what
Is the engine low? Have you measure the oil pressure? Have you cleaned or replaced the solenoid seal/filter?
Old Jul 17, 2011 | 08:22 PM
Travis R's Avatar
no oil level is fine, car drives and runs fine im not sure how to check the oil pressure.
and yeah i cleaned the solenoid screen
Old Jul 17, 2011 | 08:25 PM
What car? Maybe the oil pressure switch is bad. If it's fine, measure the oil pressure.
Old Jul 17, 2011 | 08:35 PM
Travis R's Avatar
94 hatch dx with mini me swap. i think it is the switch but why isnt the bypass trick working for me? i did the trick for jdm and usdm ecu's.
the car is made in Canada does that mean the ecu is Canadian? lol
Old Jul 18, 2011 | 09:06 AM
Travis R's Avatar
bump
Old Jul 23, 2011 | 02:06 PM
Travis R's Avatar
bump
Travis R's Avatar
pressure switch is bro?ken now. WHY ISNT THE BYPASS WORKING FOR ME???
missionaryrider
Dec 9, 2007 01:50 AM
hondacurab16
Sep 21, 2005 11:00 PM
allnapower
Apr 1, 2005 08:22 AM
slow-n-low
Oct 9, 2003 07:08 PM
