new starter and still will not start.
Old Jul 17, 2011 | 12:54 PM
viera's Avatar
Default new starter and still will not start.
I'm working on eg and the car was a DD and one day it stop starting. had the battery check and replaced the starter and still not turning, but I can pop the clutch and it turns on. pls help!
Old Jul 17, 2011 | 01:36 PM
Drive 4 fun's Avatar
Default Re: new starter and still will not start.
There are a couple of different starter threads going now on HT. Different problems. Does the starter turn over in the car? Does the starter turn the engine over?
Old Jul 17, 2011 | 02:09 PM
viera's Avatar
nope it doesn't turn over at all. I get lights inside of the car and everything else. just tried a new dissy too and no help.
Old Jul 17, 2011 | 06:50 PM
viera's Avatar
bad clutch switch!
Old Jul 17, 2011 | 07:43 PM
mechanix619's Avatar
Originally Posted by viera
bad clutch switch!
Was it your NSS? I'm having the same issues.
Old Jul 18, 2011 | 07:42 AM
frankenghia's Avatar
test the switch at the clutch and see if it completes the circuit when its depressed.
Old Jul 18, 2011 | 08:17 AM
Bad clutch switch was the answer, or a question?
Old Jul 18, 2011 | 10:10 AM
viera's Avatar
the answer. just bypass it and that's it
Old Jul 18, 2011 | 01:12 PM
civickiller's Avatar
did the plastic piece on the pedal break off or a bad clutch switch?
Old Jul 18, 2011 | 06:17 PM
viera's Avatar
just a bad clutch switch
Old Aug 1, 2011 | 06:43 PM
So my situation is similar but the car only seems to have trouble starting after driving it for a while in the hot sun. I can always start it by popping the clutch. When I turn the key all the lights come on, the main relay clicks, the fuel pump primes, and the starter clicks but it doesn't turn the engine over.
Old Aug 1, 2011 | 07:34 PM
multiple clicks or just 1 click?
Old Aug 1, 2011 | 07:59 PM
I want to say multiple but I'm not 100% sure. Next time it happens I will make sure check.
Old Aug 1, 2011 | 08:18 PM
multiple clicks= dead battery, just not enough amps to turn the starter
sigle click= bad solenoid
Old Aug 1, 2011 | 08:20 PM
Hmm, interesting, starter is new and battery is only a few months old. I'll definitely pay attention next time it happens. The only other thing I can think of is starter kill relay for alarm but the relay isn't that old either.
Old Aug 1, 2011 | 08:25 PM
doesnt the alarm relay only work on the starter signal wire? if so then the starter shouldnt click at all
Old Aug 1, 2011 | 08:37 PM
The alarm is wired into the black/white for starter and black/yellow for ignition, both sourced from ignition harness under steering column.
Honda Civic '98
Old Aug 1, 2011 | 09:01 PM
i wouldnt think ud hear a starter click if the alarm relay was bad. because you hear a click, i would think bad solenoid. they are rebuilt. i had a alternator only last me 2 weeks, a new one has lasted over 2 years now
Old Aug 2, 2011 | 12:41 AM
rd91sib18c5r's Avatar
Just get a push to start switch and hook it up to the starter and see if it turns over.
Old Aug 2, 2011 | 08:42 AM
that would be a good try, if you have a remote starter
Old Aug 3, 2011 | 08:39 AM
It happened again, after about an hour drive. I tried to start it immediately after turning the car off and all I got was one click. I'm assuming the click is the gear pushing out from the starter towards the flywheel. But yes, if the starter kill relay was going bad I wouldn't expect to hear anything.
The starter is a rebuilt Denso, so if the solenoid is bad its a shame because Denso product have never failed me before. but there's always a first time.
Old Aug 3, 2011 | 09:45 AM
the click is probably the solenoid, hardly the rest of the starter itself goes bad, its usually the solenoid.
the original was made by denso but probably the rebuild so some company that rebuilds starters.
if you have someone with you, try hitting the solenoid while someone tries to start it
Old Aug 3, 2011 | 06:44 PM
exb18c1's Avatar
Icon3 Re: new starter and still will not start.
i,m assuming that if you hear at lest one click that means that the starter gets the signal through the chain including the starter kill relay.check the ground between the engine and the body of the car.it should be good.very important.check the voltage drops on positive and negative side.if starter doesnt get all juice it needs it can not turn.. make the tests and that will reveal the trouble
Old Aug 3, 2011 | 06:48 PM
fcm's Avatar
fcm
Old Fart
Check your main grounds, batt. to chassis and chassis to engine, also check the batt. pos.(+)connection to the starter.
Next time it does not crank, try a bypass jump... https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/ 94
Old Aug 5, 2011 | 04:46 PM
I'm definitely going to run all the tests next time it happens. I've put all the tools in my car to be ready. The last time it happened and I tried to start it all I got was a click coming from under the hood. Well a click and a whirl noise. The main relay clicks and the fuel pump primes just in case I didn't cover that before.
