94 ej coupe ex missfire low rpm bog n back fire
hi guys I'm new to the site but have been working n driving hondas for years right now I'm stumped I have a 94 ex coupe.d16z6 header back exhaust n Cai . Ok a couple of weeks.ago.it started missing paid no mind to it figured is do a tune up n fix it.but since then its gotten progressivly.worse.now it spits n sputters loads up idle all the way up.to 5 grand then runs normal.I've done fuel filter cap rotor plugs wires new disty new.ecu new grounds.only.cel is code.1 I've.checked timing.2 to.3 times I can't figure.it out it will have no power pulling out bog. Spit sputters back fire n sound like.s.subbie.if I can't figure it out Imma.crush it.n start dailying.my.other coupe only things I haven't check.yet which are happenin today is im gasket n compression check any help would be awesome
getting ready to check now can anyone one tell me what good compression is or should be and not below also gonna try intake mani gasket along with a new disty yet again
Good compression varies on a couple different factors, dont just try stuff, figure it out then fix it. You can make the problem worse just changing things for no reason. i would just sell it if you dont have time for it but dont make it worse...
so checked everything expcept compression due to a bad compression tester it read less than 100 on every cylindar whcih in that case i dont think the car would run at all? but im at a blank i cant figure it out cleaned iac and egr im lost plz any one if ne input id appreciate
stallinrawlings
16
May 2, 2013 04:56 AM
Track Beast
10
Nov 21, 2010 03:35 PM
Peter94
13
Nov 9, 2010 09:00 PM
Hurricane
21
Sep 23, 2004 08:07 AM
