eg fuel pump problem
Old Jul 15, 2011 | 07:42 PM
eesupra420's Avatar
Default eg fuel pump problem
i got a 92 vx hatch.i put a built dohc d16zc in it.my car has the 4 plug engine harness and i finally found the harness i need.once i wired up the motor the fuel pump doesnt turn on when i turn the key.when i hard wire it to the battery it turns on but i dont wanna have a fuel pump switch wired up in my car.i think it might be the main relay but does anyone have any ideas.i think i might have a short somewhere.please help
Old Jul 15, 2011 | 08:00 PM
purplerain11's Avatar
Default Re: eg fuel pump problem
hmmm interesting...
Old Jul 15, 2011 | 08:02 PM
Former User's Avatar
Is the G101 ground on the thermostat housing clean and tight?
Is either hood fuse 31 or dash fuse 24 blown? See FAQs sticky for fuse box diagrams.
Old Jul 15, 2011 | 08:04 PM
eesupra420's Avatar
all my grounds are good and it doesnt blow any fuses.i made sure all my grounds where good when i dropped the motor in
Old Jul 15, 2011 | 08:06 PM
Check those two fuses with a test light or multimeter as described at the Fuse link in my signature.
Also resolder the main relay.
Old Jul 15, 2011 | 08:16 PM
eesupra420's Avatar
what do you mean by resoldier the main relay?
Old Jul 15, 2011 | 08:17 PM
http://techauto.awardspace.com/mainrelay.html
Old Jul 15, 2011 | 08:24 PM
eesupra420's Avatar
thanks.ill try this tomorrow and if it doesnt work then ill repost
Old Jul 15, 2011 | 08:31 PM
Be ready with a multimeter if the suggestions above don't happen to pan out.
Old Jul 15, 2011 | 08:38 PM
eesupra420's Avatar
i have a coupe laying around so im ready
Old Jul 15, 2011 | 08:54 PM
eesupra420's Avatar
couple*
Old Jul 16, 2011 | 04:10 PM
eesupra420's Avatar
i checked my main relay today.no broken soldiering joints or anything.i checked all the fuel pump wires and nothing is cut or shorted out.there is no blown fuses anywhere either.i turn the key once and the relay clicks.i turn it to the on position and the check engine light comes on and the relay doesnt click.doesnt that mean the relay is bad since they work on the 3 click system?
Old Jul 16, 2011 | 04:20 PM
Did you test the two fuses as I mentioned?
I am being persistent here because members regularly say their fuses are good but were not because they did not test them.
Old Jul 16, 2011 | 04:21 PM
eesupra420's Avatar
ya everything checked out fine
Old Jul 16, 2011 | 04:32 PM
Unplug the main relay and use a jumper wire to short terminal 1 (Yel/Wht wire) to terminal 7 (Yel/Grn wire) in the connector. Does the fuel pump run?
Do the same test but turn the key to ON(II) and then jump terminal 5 (Blk/Yel wire) to terminal 7. Does the fuel pump run?
Old Jul 16, 2011 | 05:32 PM
eesupra420's Avatar
isnt terminal 5 for on(1)?wouldnt i turn the key to on(1) and then jumper terminal 5 to terminal 7?
Old Jul 16, 2011 | 05:41 PM
eesupra420's Avatar
nevermind.i understand what your saying now
Old Jul 17, 2011 | 05:00 PM
eesupra420's Avatar
when i jumped terminal 1 to terminal 7 the pump didnt turn on but when i jumped terminal 5 to terminal 7 and turned the key the pump turned on.i tried to use a differnt relay but it didnt work.i guess that one was bad to
Old Jul 17, 2011 | 05:25 PM
Sounds like 15A hood fuse 31 is blown. Did you test it?
Old Jul 17, 2011 | 05:59 PM
eesupra420's Avatar
no.i will test it tomorrow
Old Jul 18, 2011 | 05:14 AM
eesupra420's Avatar
ok hood fuse 24 was my problem.i got fuel.but now i dont think i have spark.any ideas?
Old Jul 18, 2011 | 07:00 AM
1) Learn how to test fuses rather than just say they are fine.
2) The two quotes above are inconsistent. You said terminal 1 that gets power via hood fuse 31 did not make the fuel pump prime when jumped to terminal 7. This points to a blown hood fuse 31. However, you found "hood" fuse 24 blown. Hood fuse 24 doesn't exist but dash fuse 24 does. It's difficult to help you if you don't provide accurate information.
3) Test for spark. Don't guess.
Old Jul 18, 2011 | 02:35 PM
eesupra420's Avatar
i have spark now. but now it still doesnt start. it kickes over or a slit second then keep cranking. im gonna check timing in the morning. idk what else iy could be
Old Jul 18, 2011 | 04:39 PM
What did you do to get spark?
Does the fuel pump prime now?
What color is spark?
Old Aug 5, 2011 | 07:10 PM
eesupra420's Avatar
ok.i got the fuel issue straightened out.i almost had my motor started.it turned over for a couple seconds then died.now i have no spark again.all fuses are good and all grounds are good.should i replace the ignitor,coil,and rotor?
97civic07gsxr
15
Jan 14, 2009 06:25 PM
crxnatic
Jul 7, 2008 07:06 AM
electron_si
Feb 18, 2008 08:17 AM
frost_0ne
Sep 13, 2005 01:02 PM
Sloth
Sep 17, 2002 02:29 PM
