Just INSTALLED EBC RedStuff front brakes and they seem to be getting worse??
I just Installed ebc redstuff brakes on my 96 civic. I got the slotted rotors and the red stuff brake pads. They were brakeing good for 3 days but after 3 days they seem to be getting worse? its so hard brakeing now? i slam the brakes and it doesnt stop fast enough??? Has anyone else had this problem? I have to push the brake pedal all the way down for it to even brake. it seems like they are getting worse every day.
I'm not really Aftermarket guy so I don't know what quality this parts have. But I would check if you're getting any air/fluid leak. Does your brakes feel spongy? soft? sounds like you got air in system. I would check fluid level in master cylinder reservoir and make sure it's at the max line and bleed the system.
Did you imbed the brakes as soon as you finished the brake job?
these need to be imbedded 1st.
drilled and slotted rotors are a myth.read up on why these are just for show. I would run blanks with those pads.
Reds are pretty exteme as well.. green or yellow wasnt good enough?
Myth? They exist. It's not like a unicorn or something. I have drilled and slotted. Never felt any difference between them and blanks. So yes they are for show but they also work.
I also read a while back where people were complaining about EBC pads holding up and only lasting a short time.
i just bled the brakes and it feels just slightly a little better, i should i bleed it more?
pump the pedal with the engine off. it should be quite firm. remember - fluid doesn't compress.
also - with the engine running, foot on the brake - does the pedal slowly sink to the floor?
so pads require alot of heat before they grab (to better resist fade) they proably worked ok well you where wearing off the brake in compound i think red are for heavy cars (
Redstuff however as a harder compound does take longer to fully bed in to achieve its highest levels of performance (can be up to 1500 miles/2500 Kms urban use) during which time the odd "Chirp" of brake noise may be heard when starting from cold in damp and cold conditions at walking pace speed. One press of the pedal to clear the rotor of any dampness and this disappears to leave EBC Redstuff a pad that inspires confidence in all cars. The motto is be patient give the pads a full chance to bed down.
Redstuff is only available for heavier and faster CARS and does find its self at its best on slightly heavier cars or Truck and SUV applications. Selecting the right grade of EBC pad for you car, truck or SUV is important and you can see the entire EBC selection and how to choose the right brakes for your car by switching to this linked page.
swizz977
19
May 24, 2011 08:35 AM
