Ls/vtec question,wiring harness etc.
I have an obd2 b18b1 and I bought a b16a head with wiring harness injectors and chipped ecu. My question is will anything be plug and play I know the harness wont work injectors are also different. So should I buy obd2 injectors and leave my harness? Thanks for all help
Its just stock bay harness I bought motor but bottom end was junk. I read you can use ls dizzy but have to change the intake manifold? What manifold could I use
look up bambam ls/vtec
i would use a dohc vtec dizzy and a b16 or type r intake manifold and if you have the whole engine harness to bay harness from a obd1 vtec car then use that cause it will make life that much easier or just get a obd2 to obd1 conversion harness and most if not all of the sensors should macth up you have to do some research depending on which way you go
whiteef8
Mar 30, 2008 10:53 AM
