93 Civic Si - starting problem after rinse
Old Jul 14, 2011 | 05:03 AM
Hatpin's Avatar
Default 93 Civic Si - starting problem after rinse
Im in the process of welding in a new driver side floor due to a rotten floor ,
in my 93 civic si d16z6, well the other day i go to start it (day after i rinsed it)
and once the key is in it it beeps to the key, second tuen my pump should prime and i should see the dash light up, it just makes a click and nothing.
So i was a little stumped, i turned the fog lights on to see if they would go on,
i hear clicking coming from my under hood fuse box (my fog light fuse is in there as well) as i walk around the car to hear where its coming from, im standing right between them, bam they go on...... ok so i walk back and turn them off, try to start the car and it started just fine, so i let it run for 5 minutes and went to bed.
next morning same thing this time once i turned the fogs on the clicking was only short this time then they went on. then it started...
today it starts fine. any ideas? what i should replace or fuses it might be? one is going bad obv... also when i rinsed my car i noticed water drips in my pass side floor, i located it dripping through my blower box (found that a very poor design for water) possibly some wire got a bit damp? and the current dried it up ?
please help
Old Jul 14, 2011 | 07:39 AM
Former User's Avatar
Default Re: 93 Civic Si - starting problem after rinse
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
Old Jul 14, 2011 | 08:06 AM
Moonraker09's Avatar
have you check if you have verdigris on the negative port of your battery?
Old Jul 14, 2011 | 09:13 AM
Originally Posted by Moonraker09
verdigris
More commonly referred to as corrosion.
Old Jul 14, 2011 | 02:55 PM
Hatpin's Avatar
its a pretty new red top optima.
the neg terminal term was a bit lose i tightened it up, i don't think that was causing it tho.
and if it were that how would my fog lights change the start both times?
Old Jul 14, 2011 | 04:23 PM
motegicivic's Avatar
I have a feeling you might be getting water into the right side front fender and in that kick panel is the ECU, civics are known to get water in that area, I would watch how you spray that fender area.
Old Jul 14, 2011 | 06:11 PM
Hatpin's Avatar
i did notice water dripping from the blower box after i rinsed it, ill definitely watch it next time.
Old Jul 14, 2011 | 07:51 PM
virgineg6's Avatar
I think theres something in the faq section to get that to stop leaking, not 100% sure though to lazy to check
Old Jul 15, 2011 | 06:49 AM
Thanks Ron for clarifying my thought. That was me trying to translate a specific word I use in my own language to english using wikipedia i'll remember that
Old Jul 15, 2011 | 09:34 AM
Hatpin's Avatar
thanks for all the help
Fireres17
Feb 4, 2015 11:58 AM
DG19
Nov 1, 2011 07:57 PM
DG19
Mar 6, 2011 04:39 PM
trrbl1bmx
Sep 28, 2010 09:53 AM
hatchlover1
Jan 6, 2006 10:27 AM
