EK B18B1 Swap Crank No Fire. WHY?!
Old Jul 13, 2011 | 10:22 PM
FRKWOO's Avatar
Default EK B18B1 Swap Crank No Fire. WHY?!
Posting for a buddy of mines.
Swapped in a '99 complete B18B1 in a '98 ek hatch w/ y7 harness few months ago. He recently decided to fix the check engine codes, did some research seemed fairly easy to fix the light all you had to do was swap two sensors from a ls harness to the y7. Swapped out crank position sensor with a LS harness plug to fit the plug on the ls crank. problem came during the 2nd and final sensor swap, which was the IAT sensor on the intake manifold.. i was told there would be a extra wire not needed (orange knock sensor) during the splicing and sodering the 3 exposed IAT wires touched not sure which ones or how many or to where but i hear the fuel kick in as you would when you turn your key in the ignition, thought it was werid at the time but didnt think much of it til i finished up with the sensor and went to crank the car there was no fuel when you turn the key to the 2nd on position and when you crank the car all the way it cranks but doesnt fire....i checked fuel pump fuse and every other fuse i could think of and nothing was blown..what could be the problem?!
Old Jul 13, 2011 | 10:43 PM
FRKWOO's Avatar
Default Re: EK B18B1 Swap Crank No Fire. WHY?!
Link used
http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg
Old Jul 14, 2011 | 06:00 AM
FRKWOO's Avatar
ttt
Old Jul 14, 2011 | 07:31 AM
Former User's Avatar
The electrical short may have fried the ECU. Remove it for inspection.
Old Jul 14, 2011 | 08:58 AM
FRKWOO's Avatar
how would you be able to tell if a ecu is fried or not? any other possiblities?
Old Jul 14, 2011 | 09:19 AM
There's no specific electrical tests for a bad ECU.
Old Jul 14, 2011 | 09:22 AM
FRKWOO's Avatar
just swapped ecus with another obd2 ls ecu and still having the same problem?...
Old Jul 14, 2011 | 09:24 AM
Spoolinls's Avatar
see if someone has another ecu. i had two wires touch when doin my b18b swap n it fried the ecu
Old Jul 14, 2011 | 09:26 AM
Have you checked hood fuse 44 and dash fuse 13?
Old Jul 14, 2011 | 09:34 AM
FRKWOO's Avatar
yes all was in perfect condition checked almost every fuse in car and nothing was blown.
Old Jul 14, 2011 | 09:36 AM
What method did you use to check those two fuses?
Is the G101 ground wire on the thermostat housing clean and tight?
Old Jul 14, 2011 | 09:46 AM
FRKWOO's Avatar
just inspected it for disconnnections and color and all grounds are good it cranked fine after hooking up the CPS it happened after working on the second sensor.
Old Jul 14, 2011 | 09:49 AM
Click the Fuses link in my signature. Use a test light (or better a multimeter) to check for voltage to body ground at BOTH top tests tabs of fuse 44, 31, and 13.
Is there good spark at the plugs?
Old Jul 14, 2011 | 09:57 AM
FRKWOO's Avatar
also i plugged a obd2 reader it couldnt read the ecu constantly said connection error but the obd2 reader wasnt all that great either buddy got it for like $40 i think so i didnt know if it was a reliable read and respond..
Old Jul 14, 2011 | 10:13 AM
Was this true for both the original ECU and the swapped one? If so, start by checking hood fuse 43 using the method I mentioned.
Is there spark at the plugs?
Old Jul 14, 2011 | 10:37 AM
FRKWOO's Avatar
originally there was 3 engine check codes and obd reader did work in the beginning connected the CPS and deleted 2 codes and one code was left. hooked up the second sensor and obd reader started reading "connection error"
Old Jul 14, 2011 | 10:39 AM
I think this is information you've already covered. Do the fuse and spark tests I mentioned.
Old Jul 14, 2011 | 10:14 PM
FRKWOO's Avatar
ended up being a fuse..smh..thanks for all the assistance so far but i have one more issue i am not able to get the sencond sensor going no matter what i do PO112 code still comes up and i did as the link said on hooking up the IAT sensor
Old Jul 15, 2011 | 06:36 AM
Make sure no sensor connectors are swapped. Then test the IAT sensor wires for a short or open.
Wilfre114
Feb 9, 2023 08:07 AM
kaddi88
Aug 25, 2008 05:14 PM
aznlaoboi315
Sep 9, 2007 02:59 PM
silver ek
Sep 5, 2005 08:03 AM
sweetcarz02
Dec 17, 2003 12:09 PM
