CP piston cracked-melted
Old Jul 13, 2011 | 09:11 AM
hattech's Avatar
Default CP piston cracked-melted
I got this problem with CP piston. this is 2nd time it happen. It happen on the intake side for 3 of the pistons. Do you have any idea what is the cause of this problem. Is that a bad tune or the piston itself got problem? This problem happen only when i try to boosting 28psi. Here some of the picture for the piston. A little bit specs for the engine - B18C, 82mm CP, GT3082, 1200cc FIC injector. Boosting 28psi - 540whp.
Old Jul 13, 2011 | 09:12 AM
hattech's Avatar
Default Re: CP piston cracked-melted
the last picture is CP 83mm with the design of the valve pocket is a bit different compared to 82mm.
Old Jul 15, 2011 | 07:31 AM
signature sound's Avatar
Looks like your tune is lean in certain areas of the map. I think you already knew the answer to this. Kinda hard to believe that you have that high of power and dont know **** about it.
Old Jul 15, 2011 | 07:34 AM
Blown90hatcH's Avatar
Second time you have broken your pistons? Wow, people go year and years with no issues. Tune, engine build, etc. What size valves are in there? What valve springs? Post your IG, fuel, etc. maps and logs.
Old Jul 15, 2011 | 08:16 AM
cibao2ner's Avatar
lean...
Old Jul 15, 2011 | 11:06 AM
mouab18c1's Avatar
detonation?
Old Jul 15, 2011 | 11:23 AM
grumblemarc's Avatar
The Grumpiest
I'm guessing he tuned it himself.
Old Jul 15, 2011 | 01:41 PM
Uncle Dave's Avatar
Bad tune,lean,detonation,engine temp to high,air temps to high,piston to bore incorrect,turbo to small,to much back pressure, take your pick bad info to start with but its not a CP problem.
What fuel are you using?are you using EGT's for tuning or just AFR's,what cams dude the list goes on and on.
Old Jul 17, 2011 | 08:19 AM
hattech's Avatar
i guess i found the answer for this... its a PTW clearance incorrect.. the engineering shop that i sent my block to bore make it smaller than the value recommended by cp...damnn...
uncle, i'm using ron97 fuel and afr is about 11.5.. this thing only happen when i try to boost it more than 28psi..
Old Jul 17, 2011 | 08:20 AM
hattech's Avatar
this thing happen on dyno run and the afr is 11-11.5...
Old Jul 18, 2011 | 05:29 AM
Uncle Dave's Avatar
Stick E85 in it and it will live.
JDM97R
Jan 13, 2013 08:22 AM
mike93eh2
Dec 14, 2010 02:34 PM
ISELLTHEM
Apr 10, 2007 10:34 AM
eg:R
Mar 4, 2007 03:35 PM
DJ Gurgla GSR
Feb 16, 2006 03:25 PM
