00 SiR with factory B16, want b20 non vtec
Old Jul 12, 2011 | 08:06 AM
HellaFab's Avatar
Default 00 SiR with factory B16, want b20 non vtec
For simplicity sake and the fact that i need to have my head rebuilt before I add the Vtec to it.
1. am i able to put a b20b/z engine into my EK with the current wiring harness? (with no codes)
2. what ECU would work best with the B20b/z engine and the stock obd2b harness (again, no codes)
thanks,
Matt
Old Jul 12, 2011 | 02:59 PM
canadaek's Avatar
Default Re: 00 SiR with factory B16, want b20 non vtec
you would want the ecu to match the motor . can't run you current ecu as it will be looking for the vtec solnoid pressure sensor. if you get a jdm motor you will have to do something with the crank flux sensor if you want to run a north american ecu . you might want to go with a jumper harness for a obd1 ecu as the look for a lot less sensors .
Old Jul 12, 2011 | 03:15 PM
Deetz's Avatar
Crazy Honda Guy
Easy swap, and faster than a B16A, that is for sure.
Use any year B20Z, it will plug into all of your stock harness, leaving a couple plugs unused.
As mentioned, you need an ecu swap too, there are a few options-
- any usdm 99-01 crv ecu (it doesn't matter if it comes from an auto crv either, as the tranny is controlled by a separate ecu)
- any 99-01 jdm crv or orthia B20 ecu, and it's true, the jdm ecu does not look for the fluctuation sensor
- do an obdI conversion with a jumper harness and chipped ecu, many options
Old Jul 12, 2011 | 05:56 PM
xero_xero's Avatar
Use a p75 obd2 if you have to maintain emissions. jumper harness, chipped obd1 p75. crv b20z ecus are hard to find. about 5% of crvs are b20z.\
an automatic will be in limp mode without the TCM that is attached to b series motors. JDM ecu would be the best option, but internally, it is an obd1 ecu. no data connection for diagnostic.
Diggie
K Series
Aug 9, 2017 10:15 AM
mattvivsound
Engine Management and Tuning
Jul 25, 2017 09:05 AM
tdimmer17
May 17, 2011 07:45 PM
Heltonracing
15
Aug 12, 2007 05:08 PM
JDMIntegR1
Aug 22, 2004 06:34 AM
