Civic D16 idling problems
ok so i was wondering if you guys could help me here ive done research and tried about everything. I swapped a d16y7 from 98 civic to a 99 civic after ive done the swap it started to have hunting idle only when it was warm so I check the codes and found nothing so took out IACV cleaned it then when I placed it back on.. it made it worse hunting idle all the time so i tried a another used IACV.. nothing, checked vacuum lines, bleed coolant, check fuses.. starting to **** me off..
DD
DD
cel does work because the code 65 is there but has always been there since I replaced the header with no catalytic converter... I did a full swap.. idk I checked vacuum lines but I can probably check again and where would be the idle screw?
nkcalvert09
Apr 25, 2011 06:48 PM
