what trim do i have
Old Jul 11, 2011 | 06:56 PM
nicky2tone's Avatar
Default what trim do i have
i have a 92 civic hatch an i don't know if its a dx vx or cx its manual everything an 5speed an got a d15b7 but it got a navy blue leather interior that i never seen before an this is my 3rd eg can anyone help me
this is her don't mind the rims im ridin hxs now
Old Jul 11, 2011 | 07:18 PM
virgineg6's Avatar
Default Re: what trim do i have
Only way to figure it out is with the vin just enter your vin in the section asking for it http://www.hondapartscheap.com/southbay/jsp/home.jsp im sure you can just google civic vin too
Old Jul 11, 2011 | 07:25 PM
xero_xero's Avatar
your trim is noted in the vin.
2hgXXX where XXX will notate your trim.
I would guess that the trim is on the title, registration, and insurance card as well.
It being a B7, i would assume it is a DX. Cx came with an 8v B8. Vx came with the Z1. Si came with rear disc and a Z6.
assumptions are tough as all D series motors are easily interchangeable and swapped regularly. i did see a Cx, with AC, and Power steering, AND leather about a month and half ago. i assume it was an option on all trims.
Old Jul 11, 2011 | 07:49 PM
CivicBlacksheep's Avatar
10 Year Member
Cx and Vx didnt come with side moldings...you have a Dx...
Old Jul 15, 2011 | 08:27 PM
virgineg6's Avatar
yeah because in the past 19 years somebody couldnt have put them on the car!
Old Jul 15, 2011 | 09:47 PM
xero_xero's Avatar
its all in the vin number.
Old Jul 16, 2011 | 01:19 AM
10 Year Member
Right, and it just so happens to be a d15b7...which coincidently comes in a dx.....u think someone put that, along with the moldings in 19 years?
Old Jul 16, 2011 | 01:21 AM
10 Year Member
It must be. Dx clone xD
Old Jul 16, 2011 | 06:41 AM
xero_xero's Avatar
officially unsbscrobed, post up the first 6 of your vin.
Old Jul 16, 2011 | 08:31 AM
hyperblu's Avatar
idk if the d series has vins on the motor or not, but if it does will tell you if it is the original engine...
Old Jul 16, 2011 | 12:48 PM
10 Year Member
On my old d series, it didnt have a Vin on the engine
Old Jul 16, 2011 | 12:56 PM
NOFX's Avatar
H-T White Ops
My '98 Y8 has a VIN on the bottom, right where the header passes under the engine. The transmission also has a VIN near the engine code (which is on the engine).
You could always get a VIN inquiry done at Honda. That will tell you the serial number and original engine code as well.
Or you could type it into several different websites.
Your chassis code (4th-6th digits in your VIN) should also help give you an idea of the trim level.
ricky00's Avatar
just look at ur registration papers... it should tell...
Old Jul 16, 2011 | 01:03 PM
NOFX's Avatar
H-T White Ops
It doesn't always say.
Even my title says:
Year: 1988
Make: HONDA
Model: CH
Style: 2H
Series/Body: CIV2D
That's for a CRX HF btw. I'd have to go out to the cars for a registration, but I don't recall they said my trim level either.
Old Jul 16, 2011 | 01:29 PM
94EG8's Avatar
Seagull Management
A/C was available on all '92 - '95 Civics. In all Cases other than the '94 - '95 EX sedans it was installed at the dealer after the car arrived. It came in a kit and was listed as an accessory. Until '94 no civic had A/C installed at the factory, only at the dealer level.
Power steering wasn't normally available on CX/VX models (other than Canadian CX automatic models where it was standard) Not sure what the story there was, most likely swapped in at some point.
Leather was handled as a dealer option at that time. The car came in and the dealer sent it out to a local upholstery shop to have the seats and sometimes the door panels recovered in leather. '92 only CX (and possibly VX) models came with vinyl seats and door panel inserts though.
Old Jul 16, 2011 | 01:40 PM
NOFX's Avatar
H-T White Ops
Are the OP's seats actually leather or are they vinyl? I've seen the vinyl before.
Old Jul 16, 2011 | 07:42 PM
10 Year Member
Eg wont have it
Old Jul 16, 2011 | 09:43 PM
Ayyxbro's Avatar
run your vin on a site like this: http://www.decodethis.com/
it should tell you the year, country of origin, accident history, model, submodel ect..
Old Jul 16, 2011 | 09:49 PM
NOFX's Avatar
H-T White Ops
Eg wont have it
I was posting to say some D-series did.
Old Jul 18, 2011 | 02:25 AM
rhymeshark916's Avatar
That's a DX model. Enough said.
vectorsolid
17
Oct 25, 2009 01:51 PM
rice is nice
Aug 7, 2008 08:37 AM
JDMbull
19
May 16, 2007 01:13 PM
fred92htch
Aug 1, 2004 06:44 AM
boomslang
Feb 19, 2002 03:10 PM
