VTEC engagement/bad ecu. Someone help please!!!
Old Oct 2, 2002 | 04:43 AM
311's Avatar
311
Default VTEC engagement/bad ecu. Someone help please!!!
I think I have a bad ecu, and am throwing a code 22 (vtec system malfunction). I think its my ecu. Can I install a VAFC or Fields Vtec controller and bypass the ecu to engage vtec, even though my ecu wont engage it? Someone help!! I have checked the oil level, and I am sure all the wiring is correct. Anyone?
Old Oct 2, 2002 | 06:24 AM
311's Avatar
311
Default Re: VTEC engagement/bad ecu. Someone help please!!! (311)
bump
Old Oct 2, 2002 | 06:47 AM
BoM's Avatar
BoM
maybe u should cheeck your oil. and add some.
code 22 is vtec solenoid.
check for voltage, but first check your oil.
Old Oct 2, 2002 | 07:26 AM
Darkteg's Avatar
New User
do u have a jdm motor?
Old Oct 2, 2002 | 07:29 AM
311's Avatar
311
Default Re: VTEC engagement/bad ecu. Someone help please!!! (Darkteg)
yes, its a jdm b16, and i have checked the oil level as stated above.
Old Oct 2, 2002 | 10:52 AM
311's Avatar
311
ttt
Old Oct 2, 2002 | 11:48 AM
TheSaianITR's Avatar
waht year is your car, u might heave to wire it directly from the vtec solinod to the ecu, if u have a b series motor in a 93-95 EG u have wire vtec and knock sensor, if u have a 92 it comes pre-wired, check this website out it was very hepful to me http://tech.hybridgarage.com/
Good luck!!!
Old Oct 2, 2002 | 05:01 PM
Audi A4's Avatar
Default Re: VTEC engagement/bad ecu. Someone help please!!! (MiggytiMaestro)
its in a 91 integra rs.
Old Oct 2, 2002 | 06:35 PM
Sohc-Vtec's Avatar
Default vtec
I would definatelty check your soliend before u start blaming the ecu, i had the same problem earlier this year, and it turned out just faulty wiring.
Old Oct 2, 2002 | 06:45 PM
Kamin's Avatar
Default Re: vtec (Sohc-Vtec)
KAMiN's VTEC Troubleshooting article
Good luck.
dougk1401
Dec 7, 2009 08:55 AM
streetracerjoey210
11
Sep 23, 2006 03:53 PM
ezza
Mar 16, 2006 01:28 PM
Gunns
13
Jun 1, 2004 11:15 PM
311
Oct 2, 2002 04:06 AM
