Tapped b16 head on b16 bottom?
Old Jul 11, 2011 | 02:15 PM
CRXguy_88's Avatar
Default Tapped b16 head on b16 bottom?
I had the plug taken out, bought new dowels from honda and replaced the tap with a plug. Im good to go
Old Jul 11, 2011 | 04:06 PM
H22SHtec's Avatar
Default Re: Tapped b16 head on b16 bottom?
where is this head from? and ls v swap? that is the oil return to the block which looks as if it has been tapted for ls/v. you should be able to just un thread that plug and put it back together.
Old Jul 11, 2011 | 04:09 PM
Organization's Avatar
if you didnt run the motor them the headgasket should still be good and like h22shtec said take the plug out the oil galley and then plug the hole that is tapped with the appropriate plug
Old Jul 11, 2011 | 04:22 PM
H22SHtec's Avatar
^^^^ thats the way to go, cheap 2
Old Jul 11, 2011 | 10:28 PM
CRXguy_88's Avatar
Ya the motor was never ran it was just torqued first tio 22 then to 61. and it just sat and I just noticed the back of the head had the adapter for the oil line. I went ahead and took the head off, put in the original tap on the back of the head. But I tried to get the plug out of the head and I faild so I might take it to the machine shop and see if they can get it out. I dont want to strip it. Also I dont know if I can reuse the head gasket though. I bought another today but havent opened it. (because I can only return if its unopened)
Old Jul 12, 2011 | 04:47 AM
kyden's Avatar
i hope that isn't a pic of your head. that is an awful finish on it.
Old Jul 12, 2011 | 07:09 AM
that might just be the angle and the camera exaggerating the texture
Old Jul 12, 2011 | 07:11 AM
wish i was by you cause i would take the gasket
all you have to do look to see if any of the teflon coating on it has come off
Old Jul 14, 2011 | 02:26 AM
civickiller's Avatar
that isnt for oil return, its an oil feed line. just in case someone reads it
as far as dowel pins, you maybe able to get away with it but i would never try to put a head on without dowel pins. there is a reason why they make them. makes sure everything lines up, stops head from sliding around
Old Jul 14, 2011 | 12:49 PM
CRXguy_88's Avatar
ya the angle I took it at was real sharp and it was outside and real bright out. It is a really smooth surface when I felt it too.
If you want i can ship it to you, I have no use for it. send me a little dough and Ill send it if you want
Old Jul 14, 2011 | 01:40 PM
if you was close maybe but honestly keep it as a back up for another build or help a fellow near H-Techer in your area out with it
NIKADEM0
Sep 19, 2013 07:05 PM
da1haloking
Apr 22, 2009 05:03 PM
hybridpatient95
Jan 24, 2007 04:00 AM
Tuesday Club
Aug 23, 2006 01:55 PM
91-lsvtecsi
Mar 23, 2006 03:41 PM
