Constant coolant leak?
Old Jul 11, 2011 | 11:57 AM
Jz6m's Avatar
Default Constant coolant leak?
so i managed to catch this video of Steam blowing out of my reservoir tank which keeps happening after driving for awhile. does any one know why this happens?
http://www.youtube.com/watch?v=-siBXOP4GOg
Old Jul 11, 2011 | 12:12 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Constant coolant leak?
Blown headgasket would be my guess. Sorry, videos are blocked at work.
Old Jul 11, 2011 | 12:36 PM
motegicivic's Avatar
Sure it is not the radiator leaking, I can not tell from the video where the steam is coming from.
Old Jul 11, 2011 | 01:10 PM
Jz6m's Avatar
its coming from the reservoir tank, from the cap
Old Jul 11, 2011 | 04:31 PM
Def might be a blown head gasket, a typical sign will be bubbling into the overfill tank, and full steam might be it.
Old Jul 11, 2011 | 07:37 PM
godluvstegs's Avatar
is your car overheating?
also when you run your car have you check the upper and lower heater hoses to see if they are getting hot or staying cold or getting too hot
if car has been on and had a chance to warm up does the lower heater hose heat up or is it cool?
when is the last time your thermostat was replaced?
integranewb
May 7, 2007 02:12 PM
lax1089
Feb 5, 2007 08:44 PM
lsegcoupe
Feb 14, 2006 07:27 PM
korean_teg
Feb 5, 2006 06:33 PM
turbotime
Sep 26, 2005 09:55 AM
