what will i need for ENGINE SWAP
hey guys i have a 95 eg sedan and my motor is messed up so instead of fixing it i wanna replace it with a vtec. what will i need to buy besides the engine itself? transmission is auto and in good condition.
Depends on what type of motor and whatnot that you want....
Usually axles, ecu, mounts, shift linkage, header, etc to start off with. If you go SOHC again, then you can probably use your tranny, so then you can use a lot of the same stuff.
noboostedEGo
Oct 20, 2005 12:39 PM
Busta0990
30
Sep 14, 2005 11:23 AM
gabe30
Mar 15, 2005 07:14 AM
