Will a P75 ecu work better then a p28
Old Jul 11, 2011 | 08:37 AM
DaddyKin's Avatar
Default Will a P75 ecu work better then a p28
ok just a quick qustion i have a 91 civic hatch with a chipped p28 ecu that wont let me get past 3500 rpms. I'm having a hard time finding a new one so i wanna know if a p75 or a p2e will work with the harness im already running
Old Jul 11, 2011 | 08:45 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Will a P75 ecu work better then a p28
What engine?
Old Jul 11, 2011 | 08:46 AM
hondaluver19's Avatar
What are you running? And the P28 is a vtec ecu. A P75 is a non-vtec ecu. So if you are running a vtec engine, then the P75 ecu will not run the motor properly. And I'm thinking you are referring to a P2T ecu. That one is vtec, but is an OBD2 ecu. The P28 is obd1. Again, it depends on what you are running motor wise and Obd wise.
Old Jul 11, 2011 | 11:02 AM
owneyboy's Avatar
fix your busted car and then it will run better. get the right ecu it will run great. Check your VSS (speed sensor) if you have a cel and chipped ecu with launch control you wont be able to rev past that point
Old Jul 11, 2011 | 11:04 AM
DaddyKin's Avatar
Jdm d15b block
D16y8 vtec head and intake manifold
5spd Si cable transmission
Ls throttle body
Short ram air intake
Fully adjustable coil overs with lowering springs
Full Borla exhaust with 2.5" piping and hi-flow cat
4-2-1 headers
P28 ecu
Gsr black leather seats( front and back)
Old Jul 11, 2011 | 11:05 AM
DaddyKin's Avatar
what other ecu would be good to run with it if i can't find a p28
Old Jul 11, 2011 | 11:06 AM
4drferio's Avatar
p28!!!
Old Jul 11, 2011 | 11:20 AM
ozh_hawaiian's Avatar
Ive seen a couple virgin p28 ecu in the marketplace the past few days try look there... also I would try to narrow down your problem first, maybe find a friend who has a SOHC vtec motor, and put your ecu in their car to see if that is actually the problem
Old Jul 11, 2011 | 11:30 AM
DaddyKin's Avatar
THATS WHY I'M ASKING ON HERE CAUSE I'M NOT TOO FAMILIR WITH THE D SERIES, I HAD A CRX DOHC ZC ALL MOTOR ALL BOLT OF PARTS PUSHING 350 HP. BUT THIS IS MY FIRST CIVIC DON'T WANNA START MESSING WITH IT AND THEN SCREW SOME **** UP. AND FOR YOUR INFO ITS NOT BUSTED IT DRIVES FINE JUST THAT MINOR PROBLEM
Old Jul 11, 2011 | 04:23 PM
HAMOTORSPORTS's Avatar
... and it starts :/ urgggh
Check to see if the ECU is chipped. If it is, then have it tuned or get a basemap programmed chip that is set up for your engine...
Old Jul 11, 2011 | 07:58 PM
EsotericImage's Avatar
Retired Moderator
here ya go buddy:
http://www.xenocron.com/chipped-obd1...55e8f7743163f6
get your basemap and then go from there
Old Jul 11, 2011 | 09:06 PM
Wrona's Avatar
lol he's so proud of running a DOHC ZC wow great motor...not... anyway if you were smart u would notice this is a 92-00 civic forum not an EF forum second off gtfo if youre going to run nerdrage 3rd off use the search button and people told u what ecu so stop crying 4th off do some reaserch before you ask dumb questions reaserch what ecu's go to which car and than match
Old Jul 12, 2011 | 12:06 AM
xwhitchx's Avatar
Like A Boss.
lol
=P
Old Jul 12, 2011 | 07:00 AM
JDM-sol 89's Avatar
umm.. I don't know what the fully adjustable coil-overs or the black front and rear gsr seats have to do with why the car isn't revving past 3500rpm??
Old Jul 12, 2011 | 01:52 PM
owneyboy's Avatar
quoted from a guy on here with 20 posts. you gotta believe him because he said it on forums you know.
Originally Posted by hatchbackcx
Get a p28 chipped ecu if you dont have one yet.
he should get a chipped p28 cuz is better.
Freckles
20
May 3, 2012 06:17 AM
NO_FEAR_LWO
Aug 22, 2006 04:10 PM
kihun_cha
Dec 8, 2005 10:38 PM
spoonhatchblack
Nov 4, 2004 10:12 AM
