ls/vtec setup opinions!!!
Hi i have b18b1 block with gsr water pump,aem cam gears,pr3 pistons,ls/vtec golden eagle vtec line,im using ls rods,Skunk2 manifold,Dc headers 4-2-1,gsr injectors,aem intake... how much horse power u think i can get out of that???
The GSR injectors are the same as the LS ones. D and B series all hae 240cc injectors.
I have the 94 B18B1 bottom end with a 99 SI head, DC Sport Headers and short ram intake but using ls water pump and belt with ITR pistons. Dont know what the HP is but it is fun to drive and pretty quick. VTEC kicks in hard
You haven't said what head you have, but who knows what your power is until you dyno it. I'd guess maybe 155-160 whp with a decent tune but IDK really. Get some cams in there to take advantage of that high compression.
@1ls/vtec if VTEC is hitting hard you need to set crossover earlier because you're coming off the primary cam powerband before you get on your secondary cam.
