Another S2k Engine Start Install thread...
Alright guys so I've been following the DIY that was created by "Vehicross" Although now I've come to the end of the install and I've hit a dead end. I don't think its because he's working on a 2000 civic and I'm working on a 95 Civic coupe..
Source:
http://www.yefim.com/vx/redbutton/
So I put the switch in and everything is wired up accordingly but when I put the ground back on I'm not getting power to the 12v (Radio, Cigarrete lighter) which powers the switch.
However, When I hook the ST (starter switch up directly the way honda intended and I leave the IG2 wire hooked up to the relay I can feel the relay clicking, and see the power working on the radio and swtich itself.
To make a long story short I am getting power without the ST wires connected to the relay, but when hooked up to the relay I'm not getting anything. Either way I still can't get the car to turn over even though the fuel pump primes on and the car has power. I have reason to believe that the problem could be with the car having an alarm, or because the car originally came with cruise control. I only say this because as I've been looking through google/yahoo etc.. These two areas can be conflicting.
Thanks for any info.
Source:
I went to Autozone and got a brand new 30amp thinking that might be the problem and its still doing it.
http://www.acuraworld.com/forums/f27...ton-diy-71834/
dont know if it will help but found a link for you
dtwtouch
Mar 28, 2017 10:51 AM
tofuboy89
Audio / Security / Video
Mar 20, 2011 05:30 PM
