ECT CEL
Old Jul 8, 2011 | 03:25 PM
liljohn850's Avatar
Icon6 ECT CEL
So, I have a CEL 6; ECT, I changed the sensor and ive jumped the plug to make sure the fan starts. The fan kicks on when its supposed to. But I cant clear the ECL and ive reset the ECU after every attempt of trouble shooting. Any ideas?
Old Jul 8, 2011 | 03:32 PM
Former User's Avatar
Default Re: ECT CEL
Code 6 is a problem with the circuit for the 2-wire ECT sensor located below the distributor, not the ECT fan switch on the thermostat housing.
Old Jul 8, 2011 | 03:38 PM
liljohn850's Avatar
Default Re: ECT CEL
UGGGHHH. Thanks man. I'll get right back to ya and see what it is.
Old Jul 8, 2011 | 03:42 PM
liljohn850's Avatar
Default Re: ECT CEL
Uhmmm....all I see under the Dist. is a single wire plug, like a socket type?
Old Jul 8, 2011 | 03:47 PM
Default Re: ECT CEL
The 2-wire sensor is forward (toward radiator) of the 1-wire sending unit.
Old Jul 8, 2011 | 03:56 PM
liljohn850's Avatar
Default Re: ECT CEL
uhm. it looks like that spot is plugged off....
Old Jul 8, 2011 | 04:05 PM
Default Re: ECT CEL
That could explain code 6.
Old Jul 8, 2011 | 04:06 PM
liljohn850's Avatar
Default Re: ECT CEL
dude. i just swapped the plug and cleared the code. now, wheres the "second" Vtec plug go?
Old Jul 8, 2011 | 04:08 PM
Default Re: ECT CEL
The VTEC solenoid is on the other side of the distributor.
Old Jul 8, 2011 | 04:11 PM
liljohn850's Avatar
Default Re: ECT CEL
front left side of the head, in front of the dist. right? the plug in the middle of the mount is plugged.....help...
Old Jul 8, 2011 | 04:17 PM
liljohn850's Avatar
Default Re: ECT CEL
now i cleared the code 6, and now i have a code 41 and 36. 36 is trac cont. 41 is pri. o2 sensor heater....
Old Jul 8, 2011 | 04:18 PM
Default Re: ECT CEL
Plugged with what? Post pictures.
What car do you have?
Old Jul 8, 2011 | 04:27 PM
liljohn850's Avatar
Default Re: ECT CEL
theres the plug thats capped i think and the ECT plug where VTEC the second VTEC was
Old Jul 8, 2011 | 04:28 PM
liljohn850's Avatar
Default Re: ECT CEL
the grey plug is where the ECT is correct?
Old Jul 8, 2011 | 04:33 PM
liljohn850's Avatar
Default Re: ECT CEL
i think the oil pressure switch is what is capped off....
Old Jul 9, 2011 | 12:19 PM
liljohn850's Avatar
Default Re: ECT CEL
so the ECT CEL is gone, and now im getting the trac control, knock, and pri 02 heater sensor. I thought the Knock Sensor didnt matter on a P30, and it wasnt there before i swapped the plugs around to fix the ect.
93redDA
Sep 5, 2010 02:31 PM
kevinEJ
Jun 23, 2010 11:09 PM
waciii
Oct 26, 2008 06:57 PM
hondamn1320
Dec 22, 2007 02:56 PM
jaxx4k
Dec 6, 2004 07:25 PM
