(ej1 94) interior light problem
Old Jul 8, 2011 | 11:38 AM
--ej1-Marie's Avatar
Default (ej1 94) interior light problem
hi honda tech
car: civic 1994 si
problem: light interior doesn't work
light in question: cruise control (switch) , climate controle ( X2 bulb light, speed&temperature), sun roof (switch) and the roof light when i open the doors.
tanks for you help
Old Jul 8, 2011 | 11:52 AM
grumblemarc's Avatar
The Grumpiest
Default Re: (ej1 94) interior light problem
Have you checked fuses?
Old Jul 8, 2011 | 12:37 PM
tlarimer's Avatar
The cruise switch works, just doesn't light up? Replace neo wedge bulb
Replace bulbs in climate control
Check dome light bulb, if not burned out, check voltage and both door open switches.
Check sunroof fuse, relay and switch for proper operation
Old Aug 21, 2011 | 08:15 PM
The cruise switch works, just doesn't light up ? yes, all the the fuse is ok. thanks for your help
Old Aug 22, 2011 | 01:19 AM
virgineg6's Avatar
Im sure the bulbs are bad in the cruise control, climate control, speed/temp and sun roof, thats pretty common. As for the dome light, does it turn on when you put the switch to on?
Old Aug 22, 2011 | 01:57 AM
DontTouchMyEj1's Avatar
if your bulbs are fine, i suggest you Ohm that fuse because some of them are undercover bad ones in disguise. just to make sure.
And if your fuse is fine, and you replaced/checked all your bulbs. . . turn your dimmer up lol.
Old Aug 22, 2011 | 02:32 PM
yes and dimmer switch work.
Old Aug 22, 2011 | 05:53 PM
did you check BOTH fuse boxes for the interior under the steering column ?
Old Aug 22, 2011 | 07:47 PM
yes
I will change the switch to see.
Old Aug 22, 2011 | 07:51 PM
Former User's Avatar
Sounds like a bunch of blown bulbs and a bad door switch.
When many bulbs are blown, it's sometimes a sign that the alternator may be overcharging the system. You may want to have the alternator tested.
Old Aug 22, 2011 | 09:16 PM
i don't think it's my alternator
Old Aug 22, 2011 | 09:18 PM
Fliptard's Avatar
Aftermarket radio installed? If so and the "illuminate" wire I do believe was hooked up, causes the Dimmer switch to short out, and if that happens, the lights in the clutster short out and you have to replace the cluster, as well as the dimmer switch.
But remember to UNHOOK that illuminate wire, or w.e it may be called.
Old Aug 22, 2011 | 09:41 PM
Is this a guess or did you test it?
Old Aug 22, 2011 | 10:41 PM
yes i guess.
When I bought the car, I found it. I have all changed since.
http://imageshack.us/g/200/21541218618029791861064.jpg/
Old Aug 23, 2011 | 03:02 PM
bump
it is possible that the dimmer switch?
Britt Williams
Honda Civic (2001 - 2005)
Jul 30, 2021 03:17 PM
ColeCooper90
Dec 2, 2018 06:21 AM
Tokyosmash!
Honda S2000
Mar 21, 2011 01:19 AM
lpdrumer
Feb 20, 2011 04:25 PM
shortlid
Apr 15, 2007 08:46 AM
