(ej1 94) interior light problem
hi honda tech
car: civic 1994 si
problem: light interior doesn't work
light in question: cruise control (switch) , climate controle ( X2 bulb light, speed&temperature), sun roof (switch) and the roof light when i open the doors.
tanks for you help
car: civic 1994 si
tanks for you help
Re: (ej1 94) interior light problem
The cruise switch works, just doesn't light up? Replace neo wedge bulb
Replace bulbs in climate control
Check dome light bulb, if not burned out, check voltage and both door open switches.
Check sunroof fuse, relay and switch for proper operation
Im sure the bulbs are bad in the cruise control, climate control, speed/temp and sun roof, thats pretty common. As for the dome light, does it turn on when you put the switch to on?
if your bulbs are fine, i suggest you Ohm that fuse because some of them are undercover bad ones in disguise. just to make sure.
And if your fuse is fine, and you replaced/checked all your bulbs. . . turn your dimmer up lol.
Sounds like a bunch of blown bulbs and a bad door switch.
When many bulbs are blown, it's sometimes a sign that the alternator may be overcharging the system. You may want to have the alternator tested.
Aftermarket radio installed? If so and the "illuminate" wire I do believe was hooked up, causes the Dimmer switch to short out, and if that happens, the lights in the clutster short out and you have to replace the cluster, as well as the dimmer switch.
But remember to UNHOOK that illuminate wire, or w.e it may be called.
yes i guess.
When I bought the car, I found it. I have all changed since.
http://imageshack.us/g/200/21541218618029791861064.jpg/
ColeCooper90
12-02-2018 06:21 AM
lpdrumer
02-20-2011 04:25 PM
