Need Exhaust Opinion.....i want quiet....
ive got a 91 hatch with a b18 with civic type r pistons, skunk2 pro itm, cold air intake, dc header, and im runnin a 2.25 straight back with a skunk2 megapower muffler and OMG... i just wanna shoot my self in the face everytime i drive it cuz its waaaay to loud and raspy. i got a silencer for it and its still wounds like ****... i stoped getting pulled over but its just not nice to drive. im thinkin of a magnaflow hiflo cat and a borla pro xs? will that quiet it enough to think? anyone got any ideas?
Resonator will get rid of the 'bees in a can' sound and help towards a nice clean tone.
The longer the resonator the better.
You would definitely want this even with a new muffler.
Do you have a catalytic converter?
If not then you can add a cherry-bomb/glass-pack and it will help muffle and clean up the tone a lot as well.
no cat and no resinator, ya its for a bees in a can sound...maybe when i ws 16 i woulda liked it but im 28 and im gettin old... i like it quiet...lol... so i put a maganaflow hi flo cat? and a resinator both on there?
I would go for a 12"~16" resonator and see how you like it. I don't think less than 12" will give you very good results.
Out of the cat, muffler, and resonator - the resonator is least restrictive to your exhaust flow so if it works for you then job well done!
I ran a hollowed out cat and an old school Thermal muffler (probably the loudest muffler known to mankind).
After a couple exhaust tickets I added a 16" Thermal R&D resonator and, yet still loud, the noise cleaned up so much from a raspy mess into a nice clean hum.
This fit in the exhaust tunnel behind the shifter location.
Still loud, but cops didn't bother me any more.
If you feel the sound is too loud after the resonator then a different muffler or a glass-pack would be the options. If you need the catalytic converter for smog then you are probably going to be best off with a different muffler.
If you can get away with leaving the catalytic converter off then the exhaust flow less restricted (more power) and the sound will be a little louder, a little deeper, and more distinctive.
You can then fit the glass-pack in the area where the cat normally goes.
I run 2 of the longest "glass-packs" I can, then a "turbo" style muffler, and finally a "resonator" tip/ or turndown. All of this typically 3" (I pretty much only run turbos), and it is louder at idle than part/full throttle. Given the turbo quiets the exhaust down, I do the same on my B-swapped winter beaters, but run 2" instead and same results - quiet as can be.
mortificationrock
53
Aug 11, 2010 11:31 AM
user 98292739
13
Aug 2, 2005 06:18 PM
