grinding in neutral 97 ek
So my 97 ek grinds when it's in neutral. I replaced the throwout bearing and it's still grinding so I'm not sure what to do now. The manual says it's either the input shaft or throwout bearing. So should I replace the input shaft or should I be checking something else? Thanks
throwout bearings are only used when you press in the clutch and isnt used when you let off the clutch. if its in nuetral with the clutch out, then its probably the input shaft bearing
Thefinder808
13
Nov 5, 2013 06:29 AM
Pbanto
Apr 8, 2009 05:07 AM
Wes V
22
Oct 25, 2003 12:51 PM
