would this engine replace mine?
Old Jul 7, 2011 | 03:52 PM
HatchBlakKidd's Avatar
Default would this engine replace mine?
Is this engine a direct plug and play to replace my usdm d16y7? Like could I bolt my y7 trans and clutch, ecu and whatnot directly to this http://www.hmotorsonline.com/shop/sc...age&item=30023
Old Jul 7, 2011 | 04:32 PM
grumblemarc's Avatar
The Grumpiest
Default Re: would this engine replace mine?
It should. You should call them and ask as many questions as you can. There might be some modifcation you have to make to get it completely compatible as it's non-USDM.
Old Jul 7, 2011 | 04:51 PM
redm3turbo's Avatar
clutch/trans should be....Id call and check on the ECU tho.
Old Jul 7, 2011 | 05:06 PM
HondaPartsHero's Avatar
Technical Hero
As long as you swapped over your intake/exhaust manifolds (including your injectors) and oil pump (this motor doesn't have the CKF sensor) you'll be fine.
Arks
Honda Civic (2006 - 2015)
Jan 8, 2016 02:24 PM
jonathan01gsr
Jan 14, 2010 07:32 AM
BlackAC99
Aug 31, 2002 03:08 PM
JD_B18CDX
Jan 28, 2002 11:04 AM
