Boosting my B16a...need opinions on my setup
Old Oct 1, 2002 | 10:08 PM
MugenNSX's Avatar
Default Boosting my B16a...need opinions on my setup
Well its finally time to step up and gain more power. I have been researching for a few months about building a NA motor or just do a bolt on low boost turbo system. Luckily, I was able to come up on a real good deal for the turbo system. I wanted to get some feedback and opinions on my setup from all you turbo guru's. This is my first turbo setup and my goal is to have a streetable, reliable, and fun daily driver setup. Not planning to boost more than 6.5lbs or whatever the stock wastegate settings are on the TD04 15G turbo. I purposely chose this setup because I want to use my stock B16 block. If I have the urge to boost more I will then commit to building another block and do it right the first time.
Here goes.
JDM B16a1 stock block recently compression tested 165 165 165 170
Greddy SOHC turbo kit with FMIC. but using a
HKS B Series Manifold - manifold uses an internal wastegate
ITR manifold
GSR cams
Blitz BOV
Hondata 2B and tuning
DSM 450cc injectors
Walbro 255lph intank fuel pump
B&M FPR
Autometer Boost, and Oil Pressure gauges.
Blitz DTT
92-93 Integ LS Tranny w/ Clutch Specialties clutch and AASCO 9lb flywheel
Dual radiator fan Pepboys special
Am I missing anything? What kind of power can I expect? anything that I missed to make it more reliable? How much boost can a stock b16 block handle?
NA setup was running 164whp 113tq....
Boosted setup?? 220-230whp possible? If so, I will be for days.....
TIA
Old Oct 2, 2002 | 03:44 AM
Phoenix GSR's Avatar
Default Re: Boosting my B16a...need opinions on my setup (HybridEF2)
what turbo does the hks manifold hold? t25/28 only?
Old Oct 2, 2002 | 04:18 AM
Charlie Moua's Avatar
Default Re: Boosting my B16a...need opinions on my setup (Phoenix GSR)
not the t28.
Old Oct 2, 2002 | 08:21 AM
MugenNSX's Avatar
it bolts perfectly to the TD04 15 G ..Greddy turbo. I believe it uses the same flange as the t25.
#01ITR#700 has done this, but in a 00' Civic Si....Mine will be fitted to my 4door.
Here's a pic of his old setup....
HKS manifold using the TD04 15 G turbo in his Si.
Old Oct 2, 2002 | 08:38 AM
MatT3T4's Avatar
That'a a lot of fuel for a TD04 on 6.5psi, but you can always tune it down. You can safely boost more than that though man, if I were in your shoes, I'd probably be boosting between 10psi and that turbos max, 1.0 bar...every day. If you are going to boost more than the 6.5psi, maybe some colder plugs and wires to ease your mind, but other than that, it looks ok. Just make sure you get it tuned so you aren't running rich as hell.
Old Oct 2, 2002 | 09:12 AM
MugenNSX's Avatar
Default Re: Boosting my B16a...need opinions on my setup (MatT3T4)
Thanks MatT3T4........Stock block daily driver 10psi daily? 1.0bar = 14.51 psi. which is max on that TD04 15g turbo. Hypothetically, if I wanted to boost 10lb daily.....which Manual Boost controller would you suggest? I've read about them all but would like to hear from people who has had real world experiences with them. I'm also running stock ignition with Blue NGK wires. Which plugs do you also suggest i should get? model #s? Defintely tuned right after the install.....TIA for all your feedback.
Old Oct 2, 2002 | 09:14 AM
MugenNSX's Avatar
Default Re: Boosting my B16a...need opinions on my setup (chrisonepointsix)
6-7psi will be fast but once u get used to it your gonna want more & more & more hahaha
Ahhhhh Chris.....don't tell me that......please oh please.....I refuse to be a boost addict.......if so, back to the drawing board.
Old Oct 2, 2002 | 09:18 AM
MatT3T4's Avatar
You're Chris's friend? How can you stand that guy? He's a greasy wop.
Ask Chris what we did with my B16A. I had a custom Rev Hard kit...ask him how many times we ran 1.0 bar up to 9,000rpm...he'll tell you.
As for plugs, I don't know any numbers, I'm sure someone else knows though. Just go one or two degrees colder. Boost controllers...GReddy Profec B. I don't like manual ones, but I LOVE the Profec B.
Old Oct 2, 2002 | 09:31 AM
MugenNSX's Avatar
Yea I know that Outkast Chris from around the way.........I can barely stand that guy..... j/k. Chris are you going to the Dog Meat on Sunday? Matt what happened to your setup? How long did it last? What are the going prices for Greddy Profec B? u have one for sale?
Old Oct 2, 2002 | 09:46 AM
MatT3T4's Avatar
My stock B16A lasted about a year and a half running untuned, 270cc injectors, and boosting between 9-18psi, up to 9,000rpm. Don't ask me how. It met its demise due to faulty injecotr o-rings (install go bye-bye). Chris and I were about to go to LACR, and I decided to unbolt my exhaust, put on drag radials, and go make some test runs. Well as I pulled back, Chris pointed behind me, and alerted me to the pools of gasoline trailing from my car. After that, I ran it for another 6 months with burnt rings!!! hhaha. B16A's RULE!
As for the Profec...I haven't opened my vendor accounts yet, so I don't have anything for sale...yet!!!
Old Oct 2, 2002 | 09:59 AM
MugenNSX's Avatar
boost-a-holics anonymous
i might show up sunday, if i wake up and feel like driving the shitbox then i'll cruise out...
i hate driving that thing any longer than a half hour.
greasy wop's
ahahhaa.....bout time you bring the shitbox out......I still haven't seen it.....Hey Arn said he'll wake your *** up....he needs a ride...
Matt.......is this a good deal.... $250 for a Profec B with remote control dealio? let me know....i might have to scoop this up...
Old Oct 2, 2002 | 10:07 AM
MatT3T4's Avatar
$250 for a B with remote is a good deal, definitely.
Old Oct 2, 2002 | 01:11 PM
done's Avatar
01ITR#700 = good guy
he can do some cool stuff with piping
Old Oct 2, 2002 | 01:20 PM
MugenNSX's Avatar
Default Re: Boosting my B16a...need opinions on my setup (Jordo)
01ITR#700 definitely cool guy........Any one have thoughts on my setup with a 9lb. lightened flywheel? Is it too light for my setup? TIA
Old Oct 3, 2002 | 11:38 PM
MugenNSX's Avatar
Should I keep my B16 tranny for this setup or trade for LS tranny? Which is better?
Old Oct 4, 2002 | 12:55 AM
lazerus's Avatar
I'm addicted to boost.. Badly addicted Read: 28 PSI W/ Nos on top
[Modified by lazerus, 1:56 AM 10/4/2002]
Old Oct 4, 2002 | 03:50 AM
Davep's Avatar
With that type of turbo set up don't get and LS trans, keep the b16a.
shabam
Jun 6, 2009 09:57 AM
mrx
Oct 21, 2004 11:34 AM
cliff666
Apr 24, 2004 11:44 AM
mike34655
Sep 24, 2003 03:30 AM
Generation2
Jul 22, 2003 07:28 PM
