How can i recharge my A/C when... [Pics]
Old Jul 7, 2011 | 02:26 PM
Omega Blaze's Avatar
Default How can i recharge my A/C when... [Pics]
The stem is TOO Damn DEEP!?!
I also need a the lil tool to tighten up the valve inside of the hose.
The green dye shows where i was leaking..= [
Could someone tell me where i could buy the proper hose and tool to tighten the valve stem up at?
Old Jul 7, 2011 | 02:36 PM
pityocamptes's Avatar
Default Re: How can i recharge my A/C when... [Pics]
I believe its a shader valve. Autozone should sell the tool.
Old Jul 7, 2011 | 03:57 PM
dem0nk1d's Avatar
looks you have a connector on the factory R12 valve, to convert it over to the R134 style. Which is more or less like a air connector quick disconnect coupler.
Old Jul 7, 2011 | 04:08 PM
Gustav129's Avatar
The schrader valve tool can be had from NAPA for only a couple bucks. Maybe it's just screwed down too far.
I'm assuming you do have the proper tools to evac the system before you do anything?
1)Just letting refridgerant into the air is just as illegal as dumping a bucket of used oil onto the ground.
2)It's very dangerous to just crack a line open. Everything is under high pressure, you can go blind instantly if anything spreayed in your face.
3) If you crack it open and let everything spray out, then the refridgerant oil gets out, makes a mess, and causes equipment failure real quick if the correct ammount of oil isn't put back in.
Old Jul 7, 2011 | 04:46 PM
redm3turbo's Avatar
^ this....
its like a hundred bucks -(well spent in my op)
Ive been around when an a/c system high pressure line went, and it was NOT pretty. For the amount of grief and things, Id say...shore up a few bucks and take it to a shop. You can save money doing oil changes/routine maint etc.
Old Jul 7, 2011 | 05:39 PM
You guys are off.
I didn't release the freon out.
It started leaking when i took the cap off because the valve core was loose.
I just bought a schrader tool and tighten it.
My only problem now is finding the right hose or adapter to use so i can add freon.
The adapter that is on there now is too tall= [
The hose can't reach the valve core.
Old Jul 7, 2011 | 06:16 PM
dem0nk1d's Avatar
http://www.sadik.net/nissan/howto/ac_r12.htm
like i said that looks like a retro conversion valve.... check the link... above....
Old Jul 7, 2011 | 06:23 PM
It is.
What kind of hose do i have to buy to charge?
Or that kit is the only option?
Old Jul 7, 2011 | 08:06 PM
Gustav129's Avatar
You did'nt say the schrader valve was leaking. I saw the green dye elsewhere, so I assumed you had to replace the whole fitting.
Yeah, just take it to a shop. A set of hoses and guages cost about $300 my cost from Matco Tools... I'm sure you could get them cheaper somewhere, but I turn wrenches for a living, so I buy the better stuff.
Old Jul 7, 2011 | 08:42 PM
dem0nk1d's Avatar
im not one to ask about a/c i thought i just try to help. autozone has the fittings for both high and low side cost is under 10 bucks. then you just get a can of the R134 re-charge stuff, but if you're system is still R12 you're suppose to evac all the old stuff out and possibly change o-rings. this is what i've read.... also it's probably cheaper to just pay someone to charge it, to properly do it you need the three gauges, and a vac pump...
Read this post... You may want to go grab a few beers for the read...
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-how-charge-your-c-air-conditioner-conditioning-system-home-1665946/
zeroek
Apr 3, 2011 04:07 PM
JDM_SOHC
Mar 28, 2009 01:58 PM
beanbag
Aug 7, 2007 04:34 AM
killah3084
Nov 13, 2005 02:42 PM
Ri5e
Jun 28, 2002 11:32 AM
