Transmission & Drivetrain Gearboxes, Differentials, Clutches
JDM ITR Tranny>> LS 5th gear swap
Old Jul 7, 2011 | 11:52 AM
Boosted_01 R's Avatar
Default JDM ITR Tranny>> LS 5th gear swap
1) Was looking at some treads on this. From what it looks like, all you need is the main and counter shaft gears and that's all ?
2) Is everything in the JDM ITR tranny compatible with the 94-01 LS 5th gear ?
3) Any important things to know when doing this swap ?
4) Would 90-93 LS 5th gears work ?
Thanks
Old Jul 7, 2011 | 12:56 PM
David @ Synchrotech's Avatar
Default Re: JDM ITR Tranny>> LS 5th gear swap
It is a simple swap of the 5th gears. You can use the 94-01 hydro LS 5th gears or the 92-93 cable LS 5th gears. There is a slight difference in ratio but both will work fine.
Old Jul 7, 2011 | 01:17 PM
1) Couldn't ask for a better person to reply........ Whats the process for putting the new gears on... is the splines marked so it lines up a certain way ?
2) taking the gear off you use a puller....do you have too press on the gears or can it be tapped back on ?
Thanks
Old Jul 7, 2011 | 01:47 PM
The gears do not need to be aligned on the splines, just install them like the gears that you remove. I don't use a press on the B series beecause the gears come off and go back on fairly easy. Honda Bull has a really good thread showing a step by step rebuild that may help you out - https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/
If you have questions or need help during the install, feel free to give me a call and I will talk you through it.
Old Jul 7, 2011 | 02:27 PM
sweet thanks a lot.......nice to see a big company helping out the little guy :D
Old Jul 8, 2011 | 01:18 AM
low91rex's Avatar
Yeah he helped me out big when I needed it. Big up to synchro tech. But yeah the fifth gear swap is simple and your gonna love the difference it makes.
Old Apr 29, 2012 | 05:26 PM
joni_titi's Avatar
Is the synchro of the ITR transmission can be reuse with the ls 5th gear ?
Old Jun 28, 2012 | 04:08 PM
scook179351's Avatar
I have a J1 transmission that I would like to install the LS 5th gear set. Any LS 5th gear should work correct?
Old Jun 29, 2012 | 07:13 AM
You will need the 5th gears from a USDM 1990-1991 Integra LS to fit the J1.
I will PM a price to you.
Old Aug 21, 2012 | 07:49 PM
Tonys93hatch's Avatar
So its necessary to replace both counter shaft and main shaft 5th gears?
Old Aug 22, 2012 | 01:24 PM
94EG8's Avatar
Seagull Management
Yes. Using one LS gear and one gear from something else will result in shredded gears. Using two gears the correct ratio from two different transmissions will result in gear whine from different wear patterns.
Old Mar 25, 2016 | 12:52 PM
shopa's Avatar
Let's raise the dead
How much teeth are the LS gears ? Guess there is no other way to recongnize it?
94-01 hydro LS or 92-93 cable 5th gears will work on a S80, right?
Old Mar 25, 2016 | 01:02 PM
92-93 LS 26X35 2 ID marks on gear tooth
94-01 LS 25X35 3 ID marks on gear tooth
Either one will work on S80 as a match set
Old Mar 25, 2016 | 01:09 PM
shopa's Avatar
wow, thanks for the incdredibly fast answer!!!
rx191
Apr 7, 2012 02:50 PM
roycivic92
Oct 19, 2011 12:44 AM
killerpenguin21
Aug 29, 2007 06:23 PM
brokeHonda
Dec 26, 2006 06:48 PM
97turboteg
Apr 9, 2006 03:21 PM
