Piston To Cylinder Wall
Old Jul 7, 2011 | 10:55 AM
jiggacivic's Avatar
Default Piston To Cylinder Wall
not sure if this topic has been cover before but i am installing some wiseco 84mm pistons in my Turbocharged b18c Darton sleeved block and on the wiseco website it says .004 piston to cylinder wall clearance for small blocks i don't know if this applies to imports as well. so just checking for wiseco pistons what clearance is best. block will be seeing upwards 30lbs of boost, mostly strip car.
thanks
Old Jul 7, 2011 | 12:33 PM
paulzy's Avatar
Default Re: Piston To Cylinder Wall
If it's a strip oriented car and is going to be making a lot of power, go a little looser. I'd go with .005 or .006 myself
Old Jul 7, 2011 | 12:54 PM
jiggacivic's Avatar
secondly is the bottom of the cylinder wall supposed to be slightly bigger than the top, because the machine shop that honed the block, when i got back the block the walls did not look that good(a bit rough) so i took it to another machine shop to check it. when the second machine shop checked it they said the clearance at the top was okay .004 but about 2 1/2 inches from the bottom of the sleeves the size of the cylinder was a little bit bigger.
Old Jul 7, 2011 | 12:58 PM
SonicRacing1's Avatar
gotta love those machine shops that cant do a simple bore an hone SMH.....
Old Jul 7, 2011 | 01:02 PM
tagperformance's Avatar
wow now that's scary. id do .004 for NA and .006 for turbo and other forced induction applications.
Old Jul 7, 2011 | 01:25 PM
JO TECH's Avatar
im make 3.5 for all motor and 4.5 turbo street car, race cars with alot of boost 5
Old Jul 7, 2011 | 01:31 PM
jiggacivic's Avatar
well i just spoke with the second machinist and he said at the bottom is about .005 while at the top is .004 so would it be okay to just do the whole thing .005
Old Jul 7, 2011 | 02:26 PM
yes go .005 you'll be good an even all the way down
Old Jul 8, 2011 | 06:55 AM
n2mb's Avatar
how the hell do you get an extra .001 honing a block? is he using a flex hone lol
Old Jul 8, 2011 | 06:58 AM
blackeg's Avatar
somewhere around .005 will be good for a strip car.
i just redid my engine after having an incident at .0035. i went up a little to .0045 and im good to go, making just shy of 500
Old Jul 8, 2011 | 08:05 AM
MR.johnson's Avatar
lol! sounds like it.
Old Aug 11, 2011 | 01:34 PM
hattech's Avatar
ptw below than .004 and boosting more than 26psi will give u disaster..
Old Aug 11, 2011 | 09:35 PM
Boosted_B_Series's Avatar
.005 here, for 3 years street/strip. Whats odd is that I expected them to be loud and have excessive piston slap, they are quite as a mouse.. [manley pistons]
MikeD21
25
Mar 25, 2016 03:53 PM
PARADOX_sf
Feb 17, 2013 11:25 PM
Rosko
12
Mar 17, 2007 04:09 PM
B-B-K
Aug 9, 2005 09:01 PM
TurboSC
Jul 23, 2005 08:44 AM
