Want to Buy Want to Trade/Want to Buy
B16/ITR Rebuild parts, ARP Hardware, SuperTech, ITR Coolant Tube
Old Jul 7, 2011 | 09:56 AM
GI8U2racing's Avatar
Default B16/ITR Rebuild parts, Fidanza FW, ID injectors, ITR Coolant Tube
Updated Friday, July 8
I need the Type R coolant tube so that I can run it with my ITR oil cooler
I also need all of this new OEM Honda parts:
For B16A2
  • Timing Belt
  • Timing belt spring
  • Timing belt tensioner
  • Upper Main Bearings
  • Lower Main Bearings
  • Rod Bearings
  • Water pump
  • Oil pan gasket
  • Intake valve seals
  • Exhaust valve seals
  • Valve cover gasket set
  • Rear main seal
  • B16 spring-type LMA's
  • Alternator upper bolt
  • Alternator upper nut
  • Cam seals
  • Oil pump
  • Head Gasket
For 98-01 ITR
  • ITR exhaust cam
  • Cam seals
  • Oil pump
  • Oil cooler gasket
  • TB Gasket
  • Head Gasket
  • Coolant tube
  • Coolant tube o rings
  • Oil cooler joint (block nipple)
  • Thrust washer set
  • Exhaust manifold gasket
Aftermarket, I need
  • Fidanza flywheel (either new or with new surface plate)
  • Injector Dynamics 725cc injectors for B-series
  • ATI Super Damper (Race version)
Old Jul 7, 2011 | 10:05 AM
96Dc2 GSR's Avatar
Default Re: B16/ITR Rebuild parts, ARP Hardware, SuperTech, ITR Coolant Tube
have complete supertech valvetrain but not sure which springs they are 350Shipped FIRM lmk
Old Jul 7, 2011 | 10:11 AM
BlueR's Avatar
PM sent
Old Jul 7, 2011 | 12:19 PM
Fibercation's Avatar
70 shipped for the arp head studs i have
Old Jul 8, 2011 | 05:34 AM
Updated
Old Jul 9, 2011 | 06:43 PM
kindawanapokeya's Avatar
My friend has b16 LMAs pm me if you're interested
IIRC he has the original Honda packaging, not new but only used for aprox 5,000 miles. I will be helping him go through his Honda stuff tomorrow (sold his Honda's and bought a new wrx) so he has a lot of mint b16 stuff.
I sent you a pm also about the gaskets.
Old Jul 12, 2011 | 04:59 PM
TJChad's Avatar
Check my partout thread and text me if you have any interest
95EG2
Mid-Atlantic (Sales)
Apr 6, 2011 09:14 PM
3rdGteg
Sep 27, 2002 05:56 AM
schwett
Apr 24, 2002 08:37 PM
AlphaKennyWun
Feb 13, 2002 04:47 PM
