89 Honda wagovan with b18c1 swap has a hard start issue
i recently swapped a obd1 b18c1 swap into my wagovan. Im using the obd1 p72 gsr ecu, with a jumper harness,adj fuel pressure regulator,walboro 255. now the car is extremely hard to start and will only start if u spray carb cleaner in it. idk what i did wrong i followed the instructions down to the tooth and rechecked my harness to just make sure i dint mess up anywhere. can anyone give me any ideas to what it might be please i would realy like to have this ready for the next honda meet in nj next month thanks and pm or email me suggestion big01fredo2007@yahoo.com thanks
nothing i took out old 2 injector motor and swapped in the gsr and it will start but only if u put carb cleaner into it otherwise it just turns over and tries to start but nothing
so now you should have 4 injectors, right?
which injectors are you running? obd0? obd1 or obd2?
did you remember to delete the resistor box if you are using obd1 or obd2 injectors? vice versa for obd0 injectors
so i changed the fuel pump thinking it was fuel pressure considering old old motor was a 2 injector and installed a blox adj fuel regulator and still nothing
Ravenous117
Mar 27, 2014 02:11 PM
xxliljonxx1
14
Mar 21, 2012 07:57 AM
0930_SI
84
Jul 6, 2011 02:29 PM
