Transmission & Drivetrain Gearboxes, Differentials, Clutches
2009 Honda Odyssey fluid change frequency?
Old Jul 6, 2011 | 05:15 PM
Dennis T's Avatar
Icon2 2009 Honda Odyssey fluid change frequency?
I have a 2009 Honda Odyssey, how often should I change:
- the automatic transmission fluid?
- brake fluid?
-engine oil?
Thanks
Dennis
Old Jul 10, 2011 | 09:14 AM
eka11day's Avatar
Default Re: 2009 Honda Odyssey fluid change frequency?
Your owners manual should list the interval for the transmission fluid change, the brake fluid should be good for the life of the vehicle, and the engine oil should be changed every 3,000 if you are using conventional motor oil, or 5,000 if you are running a fully synthetic motor oil.
Brake fluid can collect air pockets and condensation in it, but i've never really heard of people having had major issues with it-- if you want to be on the safe side you can flush all new fluid through after you do a brake job.
Old Jul 10, 2011 | 10:41 AM
90sedan's Avatar
All of the recommended service intervals are in the owners manual, and you can simply follow the maintenance minder system if you want.
I would recommend changing the transmission fluid every 30k or sooner if you tow with the vehicle.
Brake fluid needs to be flushed every 3 years or sooner if dirty/discolored.
I would suggest running a decent oil and following the maintenance minder and change the oil at 15% life.
GailATL
Honda Civic (2016 - Current)
Jan 29, 2019 04:33 PM
Guimba
Suspension & Brakes
Feb 17, 2010 06:05 PM
Jordanasm
Honda Civic (2006 - 2015)
Oct 29, 2009 03:34 PM
Elvis1977
Jul 24, 2007 11:49 PM
