shift rod laying on ground
Old Jul 6, 2011 | 03:38 PM
scarecrow0529's Avatar
Default shift rod laying on ground
i have an 89 honda crx and the shift rod is laying on the ground. i rigged it back together and now only get 3rd and 4th gear. should i just replace the spring pin and retainer or replace the whole transmission.
Old Jul 6, 2011 | 03:42 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: shift rod laying on ground
What?
You didn't really tell us what you did to fix it, or if it got bent, or ect... Sooo, you need a whole new car.
Old Jul 6, 2011 | 05:08 PM
yourpalmike's Avatar
that is one of those things that you just dont "rig back together" replace the whole damn thing man
Old Jul 7, 2011 | 06:06 AM
4drEF's Avatar
Keyboard Humorist
IF the transmission worked (you didn't say) before your shift rod fell off, then why would you replace the transmission?
And if you never install the shift rod properly in the first place then how do you know what works and what doesn't?
Just install it with the proper hardware... except you can install a bolt instead in place of that spring pin. Do a search for the size.
Old Jul 7, 2011 | 06:17 AM
TearSDMF89dx's Avatar
the b*tch pin fell out...its funny when you want them to come out theyre welded in...mine fell out last winter... put a bolt in it just be sure to use a metric bolt otherwise youll have excessive side to side play in the shifter ...which coincidentally is probably why you only have third and fourth because the linkage can only move so far to make the gear selector pivot to get 1-2 or 5-r ...hope this helps
Old Jul 7, 2011 | 06:25 AM
cdaiscool's Avatar
I think you need a Honda Spree.
Old Jul 7, 2011 | 07:26 AM
ThatRicerDaniel's Avatar
What is a shift rod? The linkage?
Old Jul 7, 2011 | 04:04 PM
4drEF, TearSDMF89dx thanks for the help. the transmission shifted fine before the retaining clip broke and the pin fell out. so now i will find the right sized bolt and see if that does it. i will report back. once again thanx.
Old Jul 9, 2011 | 03:58 PM
i used stainless steel m8 x 35 bolt with lock nut and a couple washers. it now shifts better than it did before. thanks for the help.
DexterII
Mar 19, 2015 02:22 PM
eM1<3
Aug 8, 2009 07:20 PM
gursh d
27
Jun 2, 2007 07:18 AM
95c1v1cs1
May 4, 2002 03:19 PM
