Water - Methanol Injection - what mix do you guys use?
For those of you running water-meth injection, which method or mixture do you guys use?
After some research I have come down to ...
1. Boost Juice (Kinda expensive but pre-mixed)
2. Buying a gallon of Methanol and gallon of Dist. Water and make my own 50/50 mix.
3. Use -20F Washer Fluid (Cheap and premixed although not 50/50. I feel kinda skeptical about this for some reason...)
What do you guys use and think is a good option? Honestly, I am leaning (lol no pun
) towards no. 2
- buy a gal. of methanol and dist. water - mix my own sh**
) towards no. 2
i ran -20 when i was running around 22-23 psi for a while ran good never had a prob. When i turned it up to 30psi i switched to 50/50 methanol and dist. my a/f was around 10.8-11.0 till redline ran awesome .. my set up was skunk 2 head and forged piston and rods top mount t3 mani dbb 35r @ 30 psi for over a year
Just wondering, what is the best way to store the 50/50 water-meth mix (after you have poured it into your gallon containers)? Is it ok to keep it in a safe corner somewhere in the garage? Can the 50/50 mix ignite in extreme weather? Just tryin to be safe...
endwell17
Oct 6, 2011 03:55 PM
