Help my teggy out "/
Old Jul 6, 2011 | 11:27 AM
RecklessEJ's Avatar
Icon3 Help my teggy out "/
Ok so heres my problem my car wont turn over when it ccranks i tthought it was thethe battery the guys at autozone said it wasn't holding a ccharge so I bought a new one I go home and still the same problem I checked my spark plugs swapped the main relay cleaned the cap on the dist. Checked my fuses all checked out starter is fine I'm lost here's the wild factor tho I recently got the car and noticed the clutch pedal was really high and I was gonna do the swap tommorow at a friends house is it possible for a clutch to be completley worn out and not turn on the car ? Any help is appreciated thnx guys :]
Old Jul 6, 2011 | 11:51 AM
koss1229's Avatar
Default Re: Help my teggy out "/
When you are in neutral, the clutch has nothing to do with the problem.
Your starter does not turn over even with the new battery. Have you tried to jump-start the starter? Simply connect neg and pos wires off the battery to the starter terminals and see if that turns it over. Make sure the car is in neutral while doing that and use solid wires, there is a high circuit.
You can also try and push-start the car to confirm the starter is at fault.
Old Jul 6, 2011 | 11:59 AM
RecklessEJ's Avatar
Thnx alot bro ill try it when I get home and keep the thread updated
Old Jul 7, 2011 | 07:48 PM
LivinLoud94's Avatar
distributer or fuel pump could have failed
Old Jul 8, 2011 | 08:42 AM
8dxhatchy8's Avatar
so it cranks and cranks but no start? try the ignitor in the dizzy that was my problem too
Old Jul 8, 2011 | 10:38 AM
HondaPartsHero's Avatar
Technical Hero
Yeah I'm a bit confused, if it cranks at all its not the starter or battery. If it cranks over and doesn't start then its either:spark, fuel, air or maybe compression (usually check in that order to diagnose).
Old Jul 12, 2011 | 12:48 PM
RecklessEJ's Avatar
GUYS !!!!! figured it out ummm apparently theres a hidden killswitch to the fuel pump i traced the wiring to the fuel pump and noticed and added wire that was wrapped with the fuel pump wiring my armrest isnt bolted down and somehow switched the rocker switch on to kill the fuel pump the switch was hidden underneath the carpet where the armrest is at previous owner didnt mention this at all !!!!!! THANX FOR ALL THE SUGGESTIONS !!!!! this was a total fail
Old Jul 12, 2011 | 04:19 PM
8dxhatchy8's Avatar
wow....now move it somewhere else
Old Jul 12, 2011 | 11:02 PM
JordanG1028's Avatar
super secret kill switch ftw
Old Jul 13, 2011 | 10:01 AM
jeryhawj's Avatar
dude... you should totally take a pic of it for me! and the rest of HT! :] haha
Old Jul 13, 2011 | 11:58 AM
RecklessEJ's Avatar
already relocated ;] but man that was a trip lol thnx again guys for the suggestions heres a pic of my headache btw shes been nothing but a pain swaped out her lsd itr tranny for a gsr tranny the syncs gave out got her new axels all fluids drained and replaced shes a work in progress ....
Old Jul 13, 2011 | 12:05 PM
RecklessEJ's Avatar
EF 1990
Feb 18, 2009 10:23 AM
rukawa1one
May 29, 2005 07:06 PM
quanek4
Sep 1, 2003 03:44 PM
gumbybum
Feb 8, 2003 11:15 PM
b18tdelsol
May 18, 2002 05:59 PM
