d16z6 wont start/wont crank
Old Jul 5, 2011 | 07:52 PM
nolanator6's Avatar
Default d16z6 wont start/wont crank
basically, i have a z6 in my 95 eg hatch (cx). the tranny is from a d15b7 because i wanted the longer gears, i also decided to use the d15b7 starter. the car wont crank or anything when i start it, im postive everything is hooked up correctly. do i need the si d16z6 starter? what might be another solution?
Old Jul 5, 2011 | 07:56 PM
Former User's Avatar
Default Re: d16z6 wont start/wont crank
What work was done prior to this problem?
Can you push start the engine?
Is the transmission ground clean and tight?
Did the rubber stopper that presses on the starter switch at the top of the clutch pedal fall out?
Old Jul 6, 2011 | 03:51 PM
nolanator6's Avatar
I originally bought the car with a d15b7 with a blown headgasket and swapped in a 95 ls. Didnt pass aircare/smog and i then found out the rings were &*#$. so i swapped in a d16z6 that i had lying around. i know it ran in my buddies si before he crashed it. i may also add that i have none of the vtec wires. im using the p28 but im planning on running it now without vtec until i can find some wires. im just using the stock d15b7 harness
Old Jul 8, 2011 | 04:15 PM
nolanator6's Avatar
Tyler P
Classic Hondas
Apr 12, 2019 07:15 PM
SjEFR
Nov 6, 2010 03:36 PM
lilo_goki
Nov 11, 2008 08:03 PM
onestrongcam
11
Aug 13, 2007 01:46 PM
crx_si-r
Feb 25, 2007 10:45 PM
