Roughness on plastic bumpers after sanding
Old Jul 5, 2011 | 09:58 AM
coletrain_eg's Avatar
Default Roughness on plastic bumpers after sanding
So it's like i went too far sanding or something, its really rough and u can see it thru the primer. What can I do about this?
[IMG][/IMG]
Old Jul 5, 2011 | 10:49 AM
EGcivic_95's Avatar
Default Re: Roughness on plastic bumpers after sanding
you have to load it with primer, like self etching or filler primer. and just sand it then your good to go
Old Jul 5, 2011 | 10:54 AM
ahh i didnt think it would be that easy but if it works, cool. Thx
Old Jul 17, 2011 | 12:22 AM
Wheels 2's Avatar
Do not load it up with primer.
If you do this you could get to much film build and the paint will fail.
Plus primer/paint is always shrinking.Primer filler shrinks really bad.So if you load it up with primer and then sand it smooth after a little bit the primer will shrink and you will see little spots or specks through the paint after you have finished painting.
The way to fix it depends on what grit the scratches are?
If they are courser than 180 grit you will need to sand the scratches until you get them to 180 grit or better than go over it with a red/gray scotch brite and it will remove the little fuzzes.Then prime it block it smooth.
The little fuzzes are parts of the plastic the are no long flat with the bumper they are the material that was taken out of the scratch.
phoenix_iii
Paint and Body
10
Oct 10, 2023 11:58 PM
661rex89si
Paint and Body
18
Feb 21, 2010 08:49 PM
bubba cola
Paint and Body
25
Mar 4, 2009 04:36 AM
sawjai526
Paint and Body
Sep 7, 2008 10:13 AM
peiku
Jul 25, 2005 10:49 PM
